Old 05-05-2021, 09:41 AM   #1
Atlanta
Change subfloor
Hi all,
Anyone had their subfloor partially replaced recently? If so, what were the costs?
We gutted the AS and realize we need to replace the subfloor on both end caps, and in the fridge area.
Advice welcome.
Ariel89 is offline   Reply With Quote
Old 05-05-2021, 10:20 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
If that much needs to be replaced I would suggest doing the entire floor and more peace of mind. Granted that means more tear down.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-05-2021, 07:02 PM   #3
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Replacing the subfloor in an airstream is so common, mostly because of the propensity of plywood to rot, but there is an entire subforum on this site dealing with floor repair and replacement.
You might wanna spend a little bit of time browsing that sub forum, or simply searching for “rotten floor “to see a number of threads of people who have tackled this very issue
It is extremely common, perhaps the most annoying and common problems inherent in airstream
The cost of doing so well vary depending on whether or not you do it yourself or hire out to have it done and all the materials that you used to replace the floor. If you go with plywood, which is the cheapest material, even today with the inflated cost of everything during Covid, or if you go with a composite material like Coosa board which will last forever. Replacing it with plywood will last for about 10 years at which point you have to do this all over again when that plywood rights away. If you were planning on keeping your trailer for longer than 10 years, you might want to explore other options.
skyguyscott is offline   Reply With Quote
Replacing flood damaged subfloor gwidman Repairing/Replacing Floor &/or Frame 10 08-15-2006 09:04 PM
subfloor for dummies mudmuffin Repairing/Replacing Floor &/or Frame 12 08-02-2006 10:03 PM
Subfloor Repair Steve Heywood Repairing/Replacing Floor &/or Frame 2 01-13-2006 07:10 PM
No subfloor? Over59 Repairing/Replacing Floor &/or Frame 5 05-13-2004 06:41 PM
Sealing the Subfloor?(Pergo!) KingPing Repairing/Replacing Floor &/or Frame 4 02-12-2003 06:45 PM
