05-01-2022, 04:18 AM
#81
1994 25' Excella
Waukesha
, Wisconsin
Great solution on the bolts. Almost too bad you've got to cover them up - sort of looks like a bit of industrial art.
Richard
11018
05-02-2022, 10:37 AM
#82
1979 31' Excella 500
Mojave
I always have the solution of not installing the interior skin back on ahahahah
There were several solution for that problem, it is the best one I came up with that was not a pain in the butt and I did not have to go contently back inside between each bolts
05-02-2022, 10:41 AM
#83
Mojave
now I have only a few floor bolts to add, fill the bolts holes with body filler and that will be done. I am looking to do that the coming weekend. After that I will be able to camp in it! However, I can't do that were it is located so I plan to move it to the nearby RV park. So before that I have to be done with the exterior as they won't let me do that at the park. I still need to figure out if I'll be able to recover the shell from the scuffed marks to a polished finish or if I go for brushed metal finish
05-09-2022, 09:37 PM
#84
Mojave
PROGRESS REPORT:
finally done with the subfloor! filled up the recesses for the floor bolts with body filler, sanded and painted it. A big step is over. It took only 64 hours and about $4300 ahahahah. Just below 300 hours total.
Now time to get back on working on everything outside which I can't do at the campground.
05-10-2022, 07:12 PM
#85
1986 34' Limited
1975 27' Overlander
Conifer
That is a big milestone in your project. The subfloor is a very important structural member of the Airstream overall construction. As they say, the frame holds the body up, and the body holds the frame up. The subfloor stiffens and strengthens the whole mess.
Now on to better things in your project, like electrical, plumbing, finishing, cabinets, appliances, etc, etc.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
05-10-2022, 11:15 PM
#86
Mojave
David
A bit early for that, although I am thinking actively about it. Right now I have to do everything that is outside, like polishing etc... the RV park will not let me do that there
05-11-2022, 06:18 PM
#87
1986 34' Limited
1975 27' Overlander
Conifer
Polishing! Ugh. I've spent all winter and spring polishing Airstreams. First photo is the DW's 86 Limited 34'. It was corroded from road deicers. Second, I polished my 75 Overlander 27'. It too was corroded just from years of weather in the southeast. Now I'm polishing my son's 69 Globetrotter 21'. It is made with Alclad aluminum which makes polishing a bit easier.
Ugh. I don't envy you. I spent maybe over 100 hours pushing a polisher around on my Overlander, and the same on the Limited. It's boring drudgery work for me. But maybe, just maybe it is worth it.
David
05-11-2022, 08:32 PM
#88
Mojave
they look really nice!
I am almost done getting rid of every bit of the paint. After that I don't yet know exactly how to start since it is entirely scuffed.
Should I sand that with finer grit before doing the polishing process?
I might go with brushed metal look, maybe...
05-11-2022, 08:46 PM
#89
Mojave
Right now it looks like that
05-12-2022, 07:11 PM
#90
1986 34' Limited
1975 27' Overlander
Conifer
I have Airstream Forums post that suggest your 79 was made with H 3004 - H18 Alcoa "Brite" sheet aluminum. The post was by user ZoomZoom from California and dated 2/7/2010. Post title was Interior and Exterior Skin Material Confirmation.
My 75 Overlander was built with 6061 T6 aluminum sheet. I found it a bear to polish as the surface hardness was, well hard. The 3004 H18 spec shows a softer surface hardness, so maybe yours will be easier to polish.
I "sanded" my Overlander with green Scotch Brite to help scrape off the corrosion. Then I used my angle polisher and a sewn cotton buffing wheel at 2200 rpm and Caswell "black" polish bar. This seemed to work on the Overlander, see photo. You might want to try a less aggressive grit first on your trailer to make sure you don't leave "grind marks" in the aluminum.
Certainly your Sovereign will look much better polished. Polished Airstreams are an attractive nuisance.
David
05-12-2022, 08:43 PM
#91
Mojave
Thanks for the tip!
I actually tried steel wool tonight on the door, it does a wonder at removing the paint residues and the scuffed marks! however, I was just told that I should not be using that as metal particle would stay in the aluminum and create more corrosion. I'll try with scotchbrite as you suggested
05-12-2022, 09:04 PM
#92
1966 22' Safari
Fredericksburg
Originally Posted by Sylvain
Thanks for the tip!
I’ve used aluminum wool before for hard to get off stuff. I don’t remember what grades it comes in, but try it. Good luck
05-12-2022, 09:15 PM
#93
Mojave
Do you find that at standard hardware store? I did not know aluminum wool existed.
05-12-2022, 09:30 PM
#94
1966 22' Safari
Fredericksburg
I don’t remember where I used to get aluminum wool, but I checked Walmart’s site here in Fredericksburg and they have it.
05-13-2022, 08:39 PM
#95
Mojave
Was not able to find aluminum wool available for pick up locally. But I gave a shot at 400 grit with the orbital sander. It gets rid of all the residues, now I am able to see where I will need to re-apply a bit of paint stripper.
05-20-2022, 07:40 PM
#96
Mojave
PROGRESS REPORT: The 400 grit with the orbital sander works really well. See the pictures. It takes time but it is getting there. I have two curved sections on the front that are now shining with the sun! Not polished yet but with all the paint gone I am starting to see an Airstream somewhere.
Something that is interesting to me is the corrosion left on the aluminum by the double sided tape that was used on the back of the blue trim band. Could that have trapped water over time and corroded it?
05-21-2022, 06:35 PM
#97
Mojave
It is getting somewhere. The difference is obvious
05-21-2022, 06:43 PM
#98
1986 34' Limited
1975 27' Overlander
Conifer
That sure is a lot of work to sand off that old paint someone foolish put on it. It does look better, and even better yet if it were polished. You can do that someday when you feel like it. But it will make your trailer look like new.
David
05-21-2022, 07:29 PM
#99
Mojave
Polishing is the current plan, if I don't change my mind. For now, still have some more sanding to do to remove that stupid paint
