Old 11-19-2021, 09:05 AM   #1
Dan@LED4RV's Avatar
Denton , North Carolina
Tear drop - what light goes where
I have figured out a few simple rules to determine what light goes where. First of all you will always need gaskets under your teardrop marker lights if the light is mounted directly on the skin.
The only time you do NOT need a gasket is when there is a metal casting like the picture below. There are both curved and straight castings.
Now the only other thing to determine is, do you need a curved base or a straight base.
Most all the lights mounted on the lower part the the unit will be straight base. In the picture below, even though the lower light is on a curved panel that part of the panel is straight enough to need a straight base light. The lights at the top need a curved base light.
I did this post because so many folks get their lights only to find they have the wrong lights or they need gaskets.
One other note, before Airstream started using LEDs they had Amber lights on the top panels in front. Once they started using LEDs they did NOT have Amber with a cured base. Airstream does not sell the Amber curved base light. There are Amber LED curved base light available to replace the old incandescent lights.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 11-20-2021, 05:16 AM   #2
You need it?
tj402507 is offline   Reply With Quote
Old 11-22-2021, 06:40 AM   #3
Dan@LED4RV's Avatar
Question
Originally Posted by tj402507 View Post
You need it?
I'm not sure what the question is here. About what light
Dan Brown
Denton NC
Old 11-22-2021, 09:10 AM   #4
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I think the reason for Dan's post is to pass along information about the marker lights, not ask a question.
Thanks Dan.
thewarden is offline   Reply With Quote
Old 11-22-2021, 12:40 PM   #5
Ok have understand
Old 11-23-2021, 08:24 AM   #6
Dan@LED4RV's Avatar
Red face that is right
Thanks Dan.
I'm limited in how I can post stuff because I'm a commercial Member. I forget that some members may not know that, and the way in may come across is odd.
Thank you for clearing that up.
Dan Brown
Denton NC
Tear Drop marker Light update Dan@LED4RV Commercial Listings 4 10-05-2021 08:24 AM
Vintage Tear Drop Running Light Instal Report mello mike Lights - Interior & Exterior 5 08-19-2011 11:52 AM
1946 Dennette Tear Drop Travel Trailer Airstream eBay Watch Airstreams on eBay 0 10-11-2009 03:40 PM
Mounting Replacement Exterior Tear Drop Lights 64Overlander Lights - Interior & Exterior 1 05-12-2009 11:24 AM
tear drop marker lights 63Airstream Electrical - Systems, Generators, Batteries & Solar 22 04-11-2007 12:02 AM
