Old 12-28-2007, 02:04 PM   #1
Sioux Falls , South Dakota
PressurePro Tire Pressure Monitoring Systems
I am a new member of the Airstream Vendors forum and I would like to introduce myself. My name is Pat McFall and my husband is Mike. We have been using and selling the PressurePro System for close to 4 years. We were among the original Beta Testers and are proud to be associated with the PressurePro product. We have been full-time RV'ers for 13 years and we started out in an Airstream, WBCCI #3222. We are also Escapee Commercial Members. We "live" with our customers in RV parks across the country and take great pride in our sales and service reputation in the RV'ing community.
I am available to provide information and answer questions about the PressurePro system. I know that a lot of you are familiar with the product but there may be some newbies out there that aren't. Below are a few of the benefits of owning a PressurePro Tire Pressure Monitoring system.
The PressurePro System is a wireless, electronic Tire Pressure Monitoring System (TPMS) which can alert to low and high pressures, resulting in added safety and economy while driving. State-of-the-art technology monitors tire pressures 12,343 times a day and reports pressures when requested. PressurePro can be used on RV's and tows, trucks/5th wheels/trailers, ATV's, autos and commercial vehicles.
A low pressure tire will eventually overheat, causing premature tire failure and possibly a fire or vehicle damage. An audible alert warns of low and high tire pressure before driving becomes unsafe, giving the driver the opportunity to repair the tire before significant damage has occurred, minimizing cost and inconvenience. Fixing a tire is less costly than buying a new one and/or repairing your vehicle!
PRESSURE PRO CONSISTS OF TWO BASIC COMPONENTS:
1. Sensors simply screw onto the valve stems, replacing the caps. Sensors continuously assess the tire pressures, and wirelessly transmit each tire's pressure to the Monitor located in the dash area. You can check tire pressures while driving down the road!
2. Monitor - Available in 3 models: the RV/Tow 16 Wheel (reads up to 16 tires); the HDT/5th Wheel 34 Wheel (reads up to 34 wheels); and the Auto/Van/SUV 6 Wheel (reads up to 6 wheels). All models are equipped with Velcro for dash mounting, a cigarette lighter receptacle plug/power cord and a 3" antenna that screws on the Monitor.
Alerts - Monitors can activate an audible alarm (beeps), indicate which tire has an abnormal pressure (low or high) and display the real-time pressures of all tires at any time.
A first stage alert will "beep", flash the tire location and display low pressure (once per second) at approximately 12 1/2% under the cold running pressure for each tire.
A second stage alert will "beep", flash the tire location and display low pressure (twice per second) at approximately 25% under the cold running pressure for each tire. If no button is pressed to mute the system, the system will alert until low pressure is corrected or for a total of 15 hours. Pull over and repair.
A NEW third stage alert feature has been added recently. The Monitor will alert to a high pressure by flashing the tire position, displaying the pressure and beeping once per second. The level of alert can be set by the customer. The alert will come set at 24% high from the factory. The upper alert level can be set at 10%, 15%, 19%, 24%, 28%, 33%, 40% and 45% over the set point or turned off. The high pressure alert indicates something is causing unusual heat in the tire (brakes dragging, bearings) . Pull over and check for problems.
SPECIFICATIONS
Power Required 12V DC; draws 25 mA standby
Sensor Transmit Range Appx. 100 feet
Power Cord Plug Type USB Mini B style connector
Tire Positions 1-34 wheel positions
Operating Frequency 433.92 MHz FM
Sensor Weight Appx 2/3 oz.
Batteries Sensor and batteries replaced for +/- $25
Sensor Battery Life 3 1/2 to 5 years
Sensor Pressure Range 10-199 psi +/- 5%
If I can be of assistance, please PM or email me at: pressureprosystem@yahoo.com
Pat
Pat and Mike McFall
PressurePro System
PatMcFall is offline   Reply With Quote
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 03:49 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
PressurePro Tire Monitoring, at last dtbw Tires 14 06-01-2004 07:40 PM
tire pressure Land Yacht Deb Tires 1 01-18-2004 12:50 PM
