03-15-2012, 01:33 PM
Denton
, North Carolina
New LED light kit with sealed lights
We have a new LED light kit for the 4.25 Monarch.
This kits has the Stop Tail And Turn lights and the back up light. It takes about 10 mins to install.
These are sealed lights that fits where the bulb goes.
To install you take your 4 screws out to take the lens off, take the bulb out, insert the pig tail from the LED into the bulb socket, align the grove on the LED with the bulb socket (pictured above), place the spacer around the LED (pictured below)
Then place your Lens over both the spacer and LED light. Repeat for the other 5 light. That is 10 minutes for all 6 lights.
It works great, and gives much more light than the bulbs.
LED-kit2
Dan Brown Denton NC
03-15-2012, 01:46 PM
1971 27' Overlander
Central
, Ohio
Dan - ran across those when I was ordering some gaskets this morning. Looks like a great product and really easy to install....
03-15-2012, 01:55 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dan,
Any concerns with the TS flasher.
Thinking of switching to LED's on our Classic trlr.
03-15-2012, 02:12 PM
1997 25' Safari
Montgomery
, Alabama
NOW you're talking. What can i use the " pads" we installed last year (after I prize them off the lens.) seriously, what other use in the AS?
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
03-15-2012, 02:46 PM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
Dan: I see on these new kits you have the LED's now rated up to 24Volt.
Can you confirm this as the previous products were only rated up to 14V and I had a concern as my rear lamps work off a relay directly to the battery that receives more than 14v under charging.
Dave
03-15-2012, 03:15 PM
1979 Argosy Minuet 6.7 Metre
San Antonio
Those look like they could work for my '79 Argosy!
How would I know for sure?
03-15-2012, 09:38 PM
Denton
, North Carolina
TS concern
Originally Posted by ROBERT CROSS
Dan,
Bob,
No problems with the turn signals. It has enough power draw to make the flasher work built into the LED lights.
Dan Brown Denton NC
03-15-2012, 09:42 PM
Denton
, North Carolina
None that I know of
I would keep those pads on there. If you pry them off, they may break.
Dan Brown Denton NC
03-15-2012, 10:45 PM
Denton
, North Carolina
No problem
Dave
Dave there is no concern that these LED lights will pull more power to be a concern.
I took some pictures as I think it is a good question. I made them small so it won't take so long to load into your browser.
I don't think there will be many in this forum who will be using 24 volts and when an Airstream is using the Stop Tail and Turn it is running off the alternator which is suppose to be 13.4VDC
This first pic is the Turn signal at 13.4 VDC and it pulls .32 amps which is 320 milliamps.
This next one is at 24 VDC. It pulls .17 amps which is 170 milliamps.
The power draw for the running lights is the same for the 24 or 13.4 VDC. It is .03 amps which is 30 milliamps.
When the running lights are on, and the Turn or Brakes are applied there is no measurable power draw added.
I'm not sure how your system works but I think this is enough info to let you know what you were after
Dan Brown Denton NC
03-16-2012, 12:07 AM
1978 28' Ambassador
Morada
Looks like a 'friendly' solution to brighter rear LED lights!
Question - are those circuit boards epoxy coated to be protected from the moisture that will inevitably find it's way behind the units?
Ray & Pat; Morada, CA
03-16-2012, 10:33 AM
Denton
, North Carolina
epoxy ---yes
Yes it is an epoxy in the back and completely sealed . I have used the word sealed to get away from too much tech talk. The 1156 and 1157 sockets at the end of the pigtails are also sealed with silicon.
Dan Brown Denton NC
03-16-2012, 03:02 PM
Denton
, North Carolina
if they look like this
Vicki,
There are a few different tail light set ups for the Argosy's and what I came up with is " if your unit looks this, it will work." The Argosy pic at the bottom was from a 7.3 Minuet.
I'm think that there was a few more Argosy tail light set-ups that used the same can and 4.25 Monarch Lens. Pictured below. If this is the case, this kit will work for you.
Thanks to Out-of-Doors Mart for use of their pic.
This is the 4.25 Monarch Lens, which is now made by Grote. 90742
LED-kit2
Dan Brown Denton NC
03-16-2012, 03:10 PM
San Antonio
Thank you Dan.
Yes, that Argo picture does look like mine, guess I'm gonna have to start digging around to make sure
Vicki
03-17-2012, 08:13 AM
1999 28' Excella
Frederick
, Maryland
I ordered a set from Dan yesterday. As usual great service and fast shipping. I should have them installed before our planned trip to Assateague Island next weekend. I did a similar conversion on my previous Jayco Kiwi hybrid. WOW WOW what a difference over the wimpy 1157 bulbs. If these come anywhere close I will be very pleased and will highly recommend the change. We'll see how it works out.
Dennie
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
06-16-2012, 12:48 PM
Denton
, North Carolina
If your looking into getting this kit and have a 1975 or 76 you need to check your sockets. Airstream put an single contact (1156 style) bulb as a Stop and turn light. We do have a fix for that which is LED-kit7 . That would be 4 -1156 and 2-1157 sockets.
It would be best to look at your tail light bulbs if your unit is a 75 or 76 in either the Argosy or Airstream. You would be looking to see if you have 2 or 4 single contact bulbs. If you have 4 single contact bulbs you will need the LED-kit7
Dan Brown Denton NC
07-28-2012, 08:12 PM
Denton
, North Carolina
video
We did a video that shows how to install one of these LED lights.
LED kit2 2 - YouTube
Dan Brown Denton NC
08-26-2012, 01:34 PM
1982 31' International
Tishomingo
, Mississippi
I see from the video that you are to reuse your old gasket. Where do you get a new gasket if your old one is bad?
08-26-2012, 02:25 PM
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal
, Virginia
I have been searching for a new gasket as well.
08-26-2012, 11:18 PM
Denton
, North Carolina
Airstream dealers have them
The Airstream part number is 380226 any Airstream dealer can get them.
ODM has them on-line
Click here to see it online at ODM
Dan Brown Denton NC
