RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-25-2013, 09:03 AM   #21
1999 25' Safari
Somewhere , Ohio
TincanRitz,
I am going to start a new thread entitled "''99 25' Safari Interior" so that I'm not hijacking ChasMorgan's thread here. If you'd like, please check it out and I'll respond to your question and later today I'll post a pic or two of our bedroom.
Deb
Air Cruiser is offline   Reply With Quote
Old 07-25-2013, 02:50 PM   #22
Chasmorgan's Avatar
1999 23' Safari
Please continue on! I'm learning a lot! This has been very helpful for our 99 Safari 23'. Thanks for your input.
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 07-28-2013, 10:03 AM   #23
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Sorry Chasmorgan, I never intended to hijack your thread. I only tried to answer the question of what's behind the fabric wall in posts 1,2, and 9.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-29-2013, 09:41 AM   #24
1999 25' Safari
Somewhere , Ohio
Actually, since ChasMorgan so graciously invited us to continue on in this thread, I posted on that other thread that I'd move back over here so everything about our '99 Safaris could be here.
Deb
Old 07-30-2013, 09:19 AM   #25
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Posting here, so I can see the threads ... awesome data gathering going on
Wendy
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 07-31-2013, 08:35 AM   #26
TincanRitz's Avatar
2001 25' Safari
Wayne , New Jersey
Hi Air Cruiser,
We did decide to gut the Airstream since we found some leaks that needed to be repaired. We are waiting for flooring before we reassemble the interior. I haven't sewn in years, but now my fingers are itchy after seeing your curtains. I like the idea of leaving them loose on the bottom. If I make a pattern set for the center back window it can be a modified headboard for our bed. Did you use anything to firm up the top of the curtains (buckram, I think)? I have blackout fabric to sew into them. Hoping you post more pictures : )
TincanRitz is offline   Reply With Quote
Old 07-31-2013, 09:44 AM   #27
1999 25' Safari
Somewhere , Ohio
Hi TincanRitz! Yes, I did use a stiff buckram. I'd like to say, tho, that I only used it because of the type of heading I put into the treats. I normally don't use buckram any longer when fabricating for my business, that is, I only use it when absolutely necessary or if the client requests it. Not using it gives more of a relaxed, updated look. But, in our AS, I didn't use a true pleat, I just took a tuck to the back where I wanted the drapery pin so that the drapes would flow front to back. I did leave the track on the bottom of the wall in case in the future someone wanted to do something different.
I'm sorry I haven't posted more pictures, but it's been a little busy around here. We had rain coming (starting last night) again, so I wanted to work outside on the Bubble as much as possible -- cleaning out the old sealant from the seams so we can continue on with the polishing. Also, my Dad who is 96yrs. old lives with us and I take care of him, so that takes time too.
Have you chosen the flooring you are going to use? If so, what did you decide to go with?
Deb
Old 08-10-2013, 07:11 AM   #28
TincanRitz's Avatar
2001 25' Safari
Wayne , New Jersey
Hi Air Cruiser,
We are installing Bruce engineered hardwood flooring in natural maple. We will probably finish the flooring today (husband had business trip) and then we will spray paint the cabinets we built. I will post a picture when we are finished with the flooring.
I've decided to use some gimping on the curtains behind the couch. I found a great resource online, onlinefabrics.com. I bought 36 yards of grey gimp for $16! I have my sewing machine all primed for the curtains in the bedroom area.
We are still trying to decide on a counter top solution. There is a company near us Granite Transformations that we are going to look into.
How is your project going?
Cheryl
Old 08-11-2013, 09:58 AM   #29
1999 25' Safari
Somewhere , Ohio
Hi Cheryl!
Sounds as tho you have a lot going on, but isn't that fun!? Excited to see your pics.
I'll go out later to take a pic of our bedroom area to post; someone asked for a picture of it (we did a quick change from twin to queen -- took the easy way for that in case we ever wanted to go back to twins).
I also will be interested in seeing what you decide about your countertops; we still have ours to do (and install new sinks) -- I take it the Granite Transformations is a faux granite? (Thinking of the weight of natural granite.) (I'd also like to install some aluminum skins around for some of the walls.
Well, we have a couple of projects going on just now. We haven't really been working on our '99 Safari; we have been working on our '56 Bubble tho. We are planning to do more polishing this afternoon. Once that's done, I can seal all of the seams/windows/door and then I can get into the interior to start removing interior skins and begin the really fun part. I'm so excited about doing the interior! Fall will be here before you know it, and I would like to have it insulated/wired/new skins installed before cold weather so I can then use a small ceramic heater while working out there in the cold weather.
Thanks for sharing.
Deb
Old 08-11-2013, 07:27 PM   #30
1999 25' Safari
Somewhere , Ohio
I took a few pics of our bedroom area. First, as you can see, it isn't as easy to make the bed as a walk-around would be, but then, we also have the option to go back to twins if we should decide to without much fuss.
Unfortunately, I don't feel the pics show how much room we have on either side of the mattress -- it is quite a bit, and we use it when moving down the road to place items which we don't want to move around, such as our TV and our wall clock. We use extra pillows to pack around them and it works out great.
We have discussed building a small box-type low night stand, but haven't done it yet, DH just sits the alarm beside him on the floor.
I didn't have the pillow shams/pillows on, but I did place the quilt and you can see our bedskirt (box-pleated in center) -- both which are made out of cotton duck animal print and are washable (self-lined).
By the way, the fabric I used in the bedroom for the window treatments is the same fabric we used to reupholster the wall in the living area (this ties the two areas together).
Deb
ID:	192961   Click image for larger version
ID:	192963   Click image for larger version
Old 08-19-2013, 12:39 PM   #31
1999 25' Safari
Somewhere , Ohio
As info, we are currently checking into replacing our taillights with LED taillights. Has anyone else done this? If so, which ones did you use, where did you get them, and if you don't mind, would you please share the cost?
Thanks.
Deb
Old 08-18-2014, 09:30 PM   #32
kevhumphrey's Avatar
1999 25' Safari
mesa , Arizona
Deb
We ended up removing all the fabric and painted the wall, installed a digital thermometer and install a TV.
Name:	ImageUploadedByAirstream Forums1408415442.048412.jpg
kevhumphrey is offline   Reply With Quote
Old 08-18-2014, 09:42 PM   #33
Chasmorgan's Avatar
1999 23' Safari
How did you attached the tv bracket? If wood screws what length.
Or did you pull out the fridge and thru bolt? Thanks for the pictures,
Charlie M
TAC TX-6
Old 08-19-2014, 12:08 AM   #34
1999 25' Safari
mesa , Arizona
I used this tv mount from amazon. I also used the same length screws that were used for the thermometer. I believe a half inch but you can remove one from the therm to check. I knew that they were not going to be very long so I reinforced the mount with the 3m wall sticks.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 05-08-2016, 12:20 PM   #35
Hi,
I also have a 1999 Safari 23. I have a question about what is behind the wall covering in the nose? I removed the gaucho and replaced it with a sleeper sofa. Behind the gaucho is 4 pieces of wood which at some point enclosed the inverter and electrical connections. That has mostly fallen apart. I attempted re-screwing the 1x1 supports into the wall, but don't seem to have anything to screw in to. Maybe I'm not pushing hard enough.
What is in there?
Libbitt is offline   Reply With Quote
original interior wall covering Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-08-2008 12:14 PM
White fuzzy wall covering grantb4 Upholstery, Blinds, Walls & Interior Finishes 3 08-16-2007 09:38 AM
interior wall covering material mouse 1987 - 1989 Excella 2 04-09-2007 05:11 PM
Interior Wall and Ceiling covering PhiDor Upholstery, Blinds, Walls & Interior Finishes 16 09-30-2006 10:11 AM
Delaminated wall covering? balrgn Upholstery, Blinds, Walls & Interior Finishes 15 02-20-2006 01:09 PM
