Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1997 - 1999 Safari
Old 04-29-2012, 06:29 PM   #1
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Unhappy Water pump
Getting ready for first trip of the year. I filled up the fresh water tank so that I could flush the antifreeze from the lines into the holding tank. Check for leaks didn't see anything. When turning on water pump it catters very fast on off on off. Checked again for leaks,nothing. What's up?
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 04-30-2012, 06:49 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Clarification, please:
Does the pump clatter even with all faucets and valves closed?
When you open a facuet, does water come out of the faucet? If so, when the faucet is open does the pump come on and stay on?
Is the pump a diaphram pump or an impeller pump? On a 1999, it's probably a disphram pump, but best to ask and be sure.
Without more detail, my first guess would be that the pump needs to be primed, and is clattering because it's trying to run empty. But that's only a guess.
Old 04-30-2012, 08:42 AM   #3
1999 25' Safari
Denver , Colorado
Water Pump
Sorry I should have been more clear. When the faucets are off the pump clatters. when I turn on the faucets water come out and the pump stays on. only when I turn of the water does the pump clatter. I'm not sure what type of pump it is other than I know it's a Sure Flo.
Thanks for helping out Jim
Jim D.
Old 04-30-2012, 09:07 AM   #4
Okay. That definitely helps. Most likely culprit is a slight leak somewhere in the system (if it's not leaking out where you can see it, the water might might be leaking into a void space in your trailer). Basically, there is a loss of pressure, just enough to trip the pump, and the pressure builds back up in one or two strokes and shuts back off. You're looking for something the size of a pinhole.
If you still have antifreeze in your lines, the tint in the water could help you track down where the leak is. Check hose fittings on the pump first, and then work away from the pump until you get to each faucet.
Old 04-30-2012, 10:06 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Make sure you have enough water in your water tank. When my tank gets low the pump can't pick up enough water to pressurize the line after I shut a faucet. The pump just chatters because it is trying to build pressure and there is not enough water. With no water to build pressure the pressure switch stays on and the pump keeps running.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is offline   Reply With Quote
Old 04-30-2012, 01:12 PM   #6
Yeah. I thought of that as well, until StreamRollin said that when he opens a faucet the pump comes on and stays on. If the tank was low on water, that wouldn't happen; he'd just suck air and get spits and spurts out of the faucet.
Old 04-30-2012, 02:05 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the clattering noise constant when you have the faucets closed? If it is you either have a drain open, have a leak or the pump is sucking air. If it is not constant, you may have a small leak. If it is not constant and your pump cycles periodically and you don't have any leaks, the pressure is dropping because water us flowing back thru the pump. Minor backflow is not uncommon.
Old 04-30-2012, 06:22 PM   #8
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Twice I've forgotten to close those two "low point" drains underneath. Live and learn, and learn, and learn . . . oh no, not another "learning experience!"
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 04-30-2012, 06:41 PM   #9
1999 25' Safari
Denver , Colorado
Smile Water pump.
Well a big THANKS for all the help with my clattering pump problem. Got home from work today and checked the 3 valves by the hot water tank, tightened down the nut that is below the handle - pump stopped.Problem fixed Thanks Jim
Jim D.
Old 05-01-2012, 06:45 AM   #10
2011 31' Classic
Images: 8
Yay, success! Love it how this forum works for all of us.
