RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-02-2003, 09:34 PM   #1
cljackson's Avatar
Send a message via AIM to cljackson Send a message via Yahoo to cljackson
Strange substance in holding tank...
Hey Everyone,
We just picked up our "new" '99 Safari this weekend, and Carl has discovered a turqoise, white, and "sand"-colored pile of something in the bottom of the holding tank, and it was also clogging up the screens in the bathroom faucets. Everything seems to work okay, but we're just wondering what this might be. Any ideas?
Cheryl & Carl
cljackson is offline   Reply With Quote
Old 02-02-2003, 09:36 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Kitty litter?
Shari
Old 02-02-2003, 09:51 PM   #3
airstreamcaravel's Avatar
Maybe?
Hard Water Deposits?
Have seen similar debris in old plumbing.
Dave
(Good one Shari!)
airstreamcaravel is offline   Reply With Quote
Old 02-03-2003, 07:13 AM   #4
wallybyam's Avatar
holding tank
I would go out and buy myself the CHEAPEST wet-dry vac that I could find. Suck the tank out then through the nasty vac away. Some of the smaller ones can be had pretty darn cheap.
Bruce
wallybyam is offline   Reply With Quote
Old 02-03-2003, 07:14 AM   #5
wallybyam's Avatar
throw
throw, not through. Sorry!
Old 02-03-2003, 09:16 AM   #6
1999 25' Safari
Edina , Minnesota
Sounds to me like TST Max dry toilet chemicals, but that shouldn't be in the fresh water tank. Just a thought though.
JaceBeck is offline   Reply With Quote
Old 02-03-2003, 09:22 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
You know that same thought crossed my mind but I also discounted that since the fresh water was also showing evidence of this substance. I think Cheryl said that supposedly it was only used twice. It must have been hooked up to a mighty dirty water supply.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-03-2003, 11:56 AM   #8
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
h20 purity?
Another idea to put yourself at ease. You might want to put some of this "sand" into a container of water, and see if they dissolve. Then I'd go find the nearest water testing location and send it (or bring it if close) for chemical testing. Our water department has this feature, and I know many well systems need to be tested prior to certification for use. The yellow pages under "wells" or perhaps even "septic" will should give you some phone numbers (or even the water department? Just say you want to test your home water.)
After getting the sand out, you may want to flush your water tanks with bleach, water and baking soda. Search for "holding tank flush" or perhaps in the owners manual.
Congrats on the purchase!
Marc
Old 02-03-2003, 03:12 PM   #9
Images: 55
We have found the same substance in the faucet screens of our 77 25'. I think it is a combination of dirty water supply-previous owner not using inline water filter-and pipe corrosion. Being a newer model, it probably is a dirty water supply.
I agree though, take a sample and have it tested.
Tripp
Tripp is offline   Reply With Quote
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 08:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 12:03 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 09:00 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 04:40 AM
