Many vintage Airstreamers have updated the waste water systems on their trailers. I did so on my old 66 Trade Wind 24', one size up and one year older than your Safari. The black tank under the rear of the Trade Wind was wholly inadequate in my view. The toilet was leaking and rotted out the rear subfloor. I had a lot of rebuilding to do.
I ended up with a new black tank, and a new gray tank; both have 27 gallons capacity. I drained the tanks under the frame rail and on the street side rear like many newer Airstreams do. It is a big project. The photo shows the tanks hung between the frame rails and the dump valves below the frame rails.
My 75 Overlander had a 10 gallon gray tank. The black tank was broken. The rear subfloor was rotted out. Deja Vu! The Overlander has this weird rear drain system. It ain't the best, but I'm going to make it work. The new gray tank is located one frame bay forward. I am draining it with a pipe all the way to the rear of the trailer.
I must add that the Overlander has 3" angle irons welded to the rear of the 5" frame channel. These act as skid rails. The old tanks occupied both the 5" frame rails and the 3" skid angle irons.
I'm not a fan of composting toilets. They seem like human litter boxes to me. It takes quite some time for waste material to compost judging from my Iowa hog lot experience. Bacteria takes its sweet time. I'd rather let the sewer plant at the end of the pipe do the composting for me. A new black tank and a new flush toilet is cheaper than a composting toilet.
This is just one Airstreamer's opinion. I'm just trying to share my experiences.
David
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
