Old 10-07-2023, 04:52 PM   #1
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
Question---> Where Can I Find the Plastic Lower Drawer Hinges??
All,
The lower Drawers under the front dinette and under the side couch-sleeper have a plastic piano type hinge on the drawer doors.
The doors raise and then slide in and trays can be slide out.
Several of my plastic hinges have broken.
Where can I find these long plastic hinges?
Thanks in advance!
Name:	Airstream Drawer Hinges-broken.jpg
ID:	437567   Click image for larger version
Name:	Airstream Drawer Hinges-good.jpg
1968 22' Safari - All Original
groovzilla is offline   Reply With Quote
Old 10-08-2023, 10:57 AM   #2
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
outwater plastics
Can you make this work??
https://www.outwater.com/103-4175-PA...for-shipping=1
ALUMINUMINUM is offline   Reply With Quote
Old 10-08-2023, 06:18 PM   #3
1970 23' Safari
Marion , New York
Thanks for posting pictures of your drawer doors, Groovzilla. All the doors on my under sofa drawers are missing. I saw the tracks at the top of the openings but could not imagine what type of door fit the tracks. Now it makes sense, and I should be able to reproduce the doors.
The hinge shown in the previous post looks like it would work.
DremStremer is offline   Reply With Quote
Old 10-08-2023, 07:09 PM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I have never seen those hinges before, but, try Vintage Trailer Supply in Santa Fe New Mexico. If anybody know, they will. You might also try Vintage Trailer Window Gaskets out of Walnut California. I just looked at Vintage Trailer Parts.com and they show plastic table hinges in their closeout section. They might work! Good luck!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 10-09-2023, 04:30 PM   #5
groovzilla's Avatar
Thanks ALUMINUMINUM!
Yes I think that Hinge style will work if the width of either end of those hinges will fit over the drawer doors. If not I can probably custom fit them
Thanks again!
Old 10-10-2023, 07:47 AM   #6
NO HUMBLE OPINION
G
I edged my Formica counter-tops with fluted barbed T moldings from Outwater. They were exactly as described and shipped promptly. They have an enormous inventory of hard to find extrusions and hardware. Lots of stuff you didn't know you needed too.
I phoned in the custom-cut order, it was on my porch in a week, and they got it right the first time.
Good Service, Good Product
Good Luck!
ID:	437648   Click image for larger version
Old 10-10-2023, 03:00 PM   #7
Ron Glow's Avatar
2018 27' Flying Cloud
Haubstadt , Indiana
Originally Posted by ALUMINUMINUM View Post
G
Good Luck!
Hey Aluminuminum!
Your trailer looks super cool. I like the clean lines.
Ron
Ron Glow is offline   Reply With Quote
Old 10-11-2023, 05:27 AM   #8
Ron Glow's Avatar
Haubstadt , Indiana
McMaster Carr hardware source
Originally Posted by groovzilla View Post
All,
Thanks in advance!
McMaster Carr may be able to help. They will often find products for me even if they donít have it. Just use the contact button and ask. I found this.
Their website is the best I have ever used.
Ron
Old 10-11-2023, 10:52 AM   #9
groovzilla's Avatar
I ordered the Plastic Hinges from the Outwater Plastics link that ALUMINUMINUM posted.
They sell them in 12' lengths and have different random cut choices. They will cut as small as 12" lengths and then jump to 46" lengths.
I need (3) 19.5" pieces for the under Dinette drawers and (2) 24" pieces for the under sleeper sofa drawers.
So I ordered the (3) 46" pieces which will cover what I need and have some left over if another hinge breaks.
Cost was $20 for the 3 pieces and $21 shipping so $41 total.
I'll post photos of my repair once I get them installed.
Old 10-18-2023, 06:24 PM   #10
Vista Nic's Avatar
1969 18' Caravel
Vista , California
Plastic Bin Hinge
I used rubber contact cement to attach a strip of rubberized window shade material (not solid) to the back of the hinges. I could not find them either. This is holding up and works well. If you use a wider plastic hinge, you may have to increase the slot width for the two parts of the door when sliding back under the seat / bed (opening the storage bin).
ID:	437924   Click image for larger version
Vista Nic is offline   Reply With Quote
Old 10-19-2023, 05:12 PM   #11
groovzilla's Avatar
**Very smart idea. I was thinking one could also use a thick clear plastic similar to the material you used.
Either way great thinking to remedy the issue.
My hinges arrived today. I'll write up a post once I work on installing them.
Old 10-22-2023, 02:58 PM   #12
groovzilla's Avatar
SO the Hinges I ordered arrived. Unfortunately they are white in color which I knew before buying them. They only come in white and after receiving them I don't care for them
I am pretty sure I can make them work however I really don;t like the white color----> So after viewing your post, I am going to go your route and fabricate some clear plastic to go behind the inside of the original hinges and clue the plastic material down like you did. This way you won't be able to see any of the material being used.
I'll add some photos when I get around to doing the project. I have 5 door fronts in total to repair.
Old 11-26-2023, 12:46 PM   #13
groovzilla's Avatar
Drawer Hinge Update
Well I finally got some time to dive into the removal/replacement of the drawer hinges.
**The plastic hinges I ordered are a great fit - The width of both openings of hinges match very well to the drawer width.
Since the new hinges are white, I chose a tan spray paint and just got done spraying the new hinges.
*I used small clamps to support the hinges during the painting - Keeps them off the table and since I am only painting the surfaces that can be seen when drawers are in place, works well.
Once I get them installed I will take some final photos - Hinges are currently drying and taking a bit more time due to the cold weather.
ID:	439039   Click image for larger version
ID:	439041   Click image for larger version
Old 11-26-2023, 12:47 PM   #14
groovzilla's Avatar
More photos of hinges drying after painting.
ID:	439043   Click image for larger version
Old 11-26-2023, 04:49 PM   #15
groovzilla's Avatar
Here is photo with the 2 new replaced hinges on the 2 left side drawers.
*Drawer on far right has the original plastic hinge.
Old 11-26-2023, 05:24 PM   #16
1970 23' Safari
Marion , New York
Thanks for the update. That's a great original looking repair. All my doors were missing from my Airstream. Now I know how to make some new ones.
Old 11-26-2023, 06:41 PM   #17
groovzilla's Avatar
Should be very easy to make new doors. And the plastic hinges work great. I simply stapled the new hinges on the undersides just as the originals were done.
The smaller top door that slides along the tracks has wooden blocks on either side that keep it aligned/centered when it is slid open or closed.
Old 11-28-2023, 04:11 PM   #18
groovzilla's Avatar
Tips for installing new hinges & making the drawer doors
More info if you are making the drawer doors and also tips on paint color.
-The doors are 3/8" thick.
-Home depot makes really nice 2'x4' 3/8" plywood panels w/top maple layer for nice grain and finish.
-Larger door has a 45 degree angle cut at bottom for finger space when opening.
-Doors have a small locking wheel at inside bottom to secure door shut
-smaller top door has 2 small wooden blocks to keep it lined up on the interior track
-great paint match is Rustoleum Satin Enamel in Dark Taupe color - The new cans have an assortment of built-in spray tips and tip I used gives a nice fine spray.
ID:	439082   Click image for larger version
ID:	439084   Click image for larger version
Old 11-28-2023, 04:14 PM   #19
groovzilla's Avatar
Finished replacing the hinges on the last 2 doors under sofa pull out sleeper.
The larger doors under sofa sleeper are longer but just as easy to replace hinges.
Just replaced the 2 hinges that were broken.
Name:	lower drawers final.jpg
Old 11-28-2023, 05:03 PM   #20
1970 23' Safari
Marion , New York
Thank you for the additional details on making these doors. It's very helpful.
My goal as I rebuild my Airstream is to keep the original look and these flip up doors were original to my 1970 trailer. Yours are the first pictures I've seen showing how these unique doors function.
2022 Globetrotter galley lower drawer slides part number BCleveland Cabinets, Counter Tops & Furnishings 5 08-22-2023 11:58 PM
Door Hinges converted to Piano Hinges Ray Eklund Cabinets, Counter Tops & Furnishings 19 06-01-2022 08:44 AM
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 10:47 AM
'68 Ambassador full length plastic hinges Headhog Cabinets, Counter Tops & Furnishings 2 06-19-2013 10:34 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 12:01 PM
