RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-31-2016, 09:31 PM   #1
Send a message via AIM to spaceghost65
Original antenna wire routing?
Originally did this wire eventually ever come out into the interior of the trailer? I found what looks to be like a radio antenna wire on the right side of the front cabinet, but it doesn't match thickness/color. I would love to attach some coax to this wire an pull it through to the inside of the trailer.
Any help is appreciated.
Coming soon: a crowd pleaser.
spaceghost65 is offline   Reply With Quote
Old 08-01-2016, 09:44 AM   #2
Apologies this is the water pump wiring on the street side of the trailer, I meant to take a photo of the other side. I will update this evening.
I don't run a water pump or holding tank up in the front of trailer anymore, everything has been relocated to the rear.
Old 06-27-2017, 09:59 AM   #3
1967 22' Safari
Elkton , Maryland
Here are a couple of pictures of the antenna on the outside of the trailer. The antenna is original to the trailer. You can see the cord/wire going in.
I'll see if I can find the wire on the inside and get pictures there.
Name:	Airstream Antenna Pic 1.jpg
ID:	288298   Click image for larger version
Name:	Airstream Antenna Pic 2.jpg
NJ Amanda is offline   Reply With Quote
Old 06-28-2017, 11:15 AM   #4
1967 22' Safari
Elkton , Maryland
Antenna Wiring Pictures
Hi again!
I cleared out the overhead cabinet above the front window to get to the wiring (it needed to be cleaned out anyway) and have some more pictures.
I concluded that from where the antenna wire comes into the trailer and into the cabin, the wire appears to be threaded through the trailer wall just above the front window. The wire then comes into the overhead cabinet just above the corner of the window that is opposite where the wire went into the trailer.
I have pictures of where it comes in with the (I think original) radio moved out of the way and with the radio in place.
Happy wiring!
Name:	Airstream Antenna Pic 3.jpg
ID:	288328   Click image for larger version
Name:	Airstream Antenna Pic 4.jpg
Name:	Airstream Antenna Pic 5.jpg
Old 06-28-2017, 12:20 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I made a small aluminum patch panel to cover the hole and installed an F-connector in place of the old 300-ohm twin lead connector. Inside I attached TV cable and ran it into an overhead cabinet where I can hook up my TV. Outside I can attach the antenna lead to the connector or if I'm at a campground with cable TV, I run a cable from the connector to the campground cable box.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Bambi II original battery wire routing PA BAMBI II 1964 Bambi II 0 07-09-2014 08:11 PM
1967 AS 28' brake wire routing Jim & Mitzi Brakes & Brake Controllers 4 12-03-2013 07:33 PM
AV wire routing in '06 Safari ShullsinUtah General Repair Forum 0 10-02-2013 03:47 PM
Routing a XM/Sirius Antenna Wire wolverine Audio, Video & TV 1 05-29-2013 04:29 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
