RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-19-2018, 04:32 PM   #1
1968 22' Safari
Jamul , California
One man end cap install.
I'm ready to install the fiberglass endcaps on my 68 Safari, but the front one is kind of heavy and unweildy. Any suggestions about how to raise it and hold it in place while I rivet it up?
bsaa10bill is offline   Reply With Quote
Old 04-19-2018, 06:03 PM   #2
Images: 59
It's very difficult for one person.
Attach a 2x4 ledge under the front window to rest the lower edge on.
Screw some cleats to the floor and use 2x4 jack posts to support the center of the end cap.
Start putting in clecos at the center line upper edge.
Check the bottom edge hole alignment and cleco if possible. You may need to push in the center of the cap to get the holes lined up. Have lots of clecos available.
You might also want to use 5/32" rivets instead of 1/8". It's likely some of the holes in the fiberglass are wallowed out from years of road use.
Good luck. It's one of the toughest jobs to do one-handed.
Old 04-20-2018, 11:22 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
end cap support
I made these to take the end caps down. Like you I was working solo. Sorry can't give you any dimensions. I'm not putting the fiberglass caps back up so I dismantled the support.
Name:	end cap support 1.jpg
ID:	309119 Click image for larger version
Name:	end cap support back brace.jpg
The shorter support in the back has a lip for the bottom edge of the cap to sit on.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
One man's trash is another man's treasure richie rich Generators & Solar Power 30 07-28-2020 08:12 AM
Loose shaft one one end The Colonel Awnings 8 03-17-2017 09:40 PM
Pickup truck cap or no cap? weber.roger Airstream Lifestyle 28 12-04-2015 07:22 AM
One man's point of view yukionna Off Topic Forum 16 09-12-2007 10:58 AM
Sprung door... one man's solution Safari Tim Doors & Locks 1 08-07-2004 07:41 PM
