RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-19-2014, 03:21 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Need furnace and Air Conditioner
Hello, I steered some friends into grabbing a 67 Safari. It's missing the downdraft, undercounter heater that once was there. What should we get to replace it? Also, it needs an A/C unit added (never had one). What do you folks recommend?
Thanks!
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 11-19-2014, 09:36 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I have a 66 Tradewind with the original furnace. It works fine, but hey it is 48 years old and has two problems- first I don't trust it; there may be a leak in the heat exchanger. Second, the furnace fan is kinda noisy and uses too much battery. This is a problem as I mostly boondock.
I just ordered a new furnace today. It is a 12,000 btu/hr Atwood unit with spark ignition and a very efficient fan motor (1.8 amps). This is smaller than the original furnace which was 20,000 btu/hr, but I think it will be fine. I don't usually camp if it is much below freezing. The photo below came from the Technical Installation Manual.
I would never install an ac on top of a 66 Safari. Totally overkill and it really ruins the looks of a very attractive Airstream. I carry my small 5,000 btu/hr AC unit in the bottom of a cabinet until I need it then install it in a side window. I designed a mounting bracket for it and it takes less than 10 minutes to install. 90% of the time we camp, we never need to install it. Here are some photos, and you can read a thread on it at the following location:
http://www.airforums.com/forums/f427...nny-91215.html
You may also want to look at a thread called "dan's 66 tradewind improvements". Feel free to pm me if you have any questions. I will help you all I can.
Good luck, Dan
ID:	227002   Click image for larger version
TouringDan is online now   Reply With Quote
Air Conditioner / Furnace Thermostat aa9zz Sprinter and B-van Forum 15 10-08-2013 12:03 PM
Air Conditioner and Outlets Stopped Working - Need Your Input flyfishrra Electrical - Systems, Generators, Batteries & Solar 17 08-30-2012 03:01 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 11:43 AM
Original Armstrong furnace Co Air conditioner question. Mark K Airstream Motorhome Forums 3 09-20-2003 10:04 PM
New Airstream - Air conditioner/Furnace problem mariffe Electrical - Systems, Generators, Batteries & Solar 12 04-16-2003 05:26 PM
