RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-08-2016, 10:05 AM   #1
1968 22' Safari
NorCal , California
Leaking fixed window help please
I'm cross posting from the window forum in hopes of getting some help from someone who has done this before.
Please let me know if it is improper forum etiquette to cross post.
I'm going to try and tackle the leaky fixed window that is to the right of the door as we've got a good amount of rain expected in the coming week.
I have what I believe are the needed supplies but not the know-how details. We've had our AS for about a month now so I'm still fairly green.
I could use some help please.
The window has a bead of clear silicone caulk on the outside and the gasket inside is shrunken at the mitered corners.
The process that I think I'm supposed to do is; I remove the old gasket from the inside, use a utility knife between the glass and the old butyl? tape, remove window and clean old tape and silicone.
Replace with new butyl tape, insert window, apply new gasket and then caulk the outside with what? I have TremPro 635 Polyurethane caulk and TremPro 644 RTV Silicone on hand - just not sure if either is appropriate.
How do you get the gasket in place? Just push it into the space? My fear is that I'll easily get the window out and not be able to get it back in sufficient to not leak again.
Thanks in advance for any help!!
Laurie
Photos show old gasket inside and the bead of silicone outside.
ID:	273139   Click image for larger version
Gratitude for all there is and all there isn't!
Photos of our gal.
WBCCI #19233
EmptyNesters is offline   Reply With Quote
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 12:38 PM
Please help, I'm so sad :( 2006 Safari leaking... J5MM Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-21-2010 03:49 PM
Old inlet leaking....help please! Smoky Fresh Water Systems 14 10-21-2009 09:42 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 02:59 PM
'68 Globetrotter fixed window repair JUDITH L. SMITH Windows & Screens 3 04-08-2004 08:26 PM
