RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-26-2014, 09:44 AM   #141
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
After rebuilding and refinishing all your woodwork it will be a snap to refinish the dinning room table, while watching Sheldon Cooper on the Big Bang Theory.
Old 11-26-2014, 01:17 PM   #142
DFlores's Avatar
1968 22' Safari
Buda , Texas
No way, that table has the scars of many of our 4 kids projects from elementary school thru high school. Memories of building bird houses in Cub Scouts to making costumes for many a halloween costume.
We can't touch that table.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 11-26-2014, 01:32 PM   #143
DFlores's Avatar
1968 22' Safari
Buda , Texas
Originally Posted by dbj216 View Post
Wow, you sure put new meaning into "whip up something in the kitchen". And yes, your wood is finished beautifully. My old Trade Wind needs refinished, maybe someday. Your front overhead cabinet you built is super. Mine is molded plastic with a wood facia.
I wanted to ask how you are making cabinet doors. My trailer has plywood closet doors that are a little shy of 1/2" and then routed around the perimeter about a 1/2 inch wide, and 1/4" deep. This makes a recess that fits into the cabinet framing. I don't have a router that can make that cut, so I used 1/4" plywood and attached 1/4" frame to it to create the effect of the recess.
I'm really enjoying this thread! "Good things from the Deflores kitchen".
David
This is our "back porch" wood shop, where the cabinet doors were routed as you described.
DFlores
David & Diana
Old 11-26-2014, 01:40 PM   #144
DFlores's Avatar
1968 22' Safari
Buda , Texas
The "Gaucho"
Diane, takes all the pictures, captures me "at my best". The gaucho was rebuilt with extra reinforcing from the original 1"x1" framing members, we put in 1"x3" framing because I did not think the original was a very good design.
I played with the future cushion widths and came up with 20", 15" and 14" for a total of 47" wide pulled out bed.
ID:	227404   Click image for larger version
ID:	227406   Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 01:46 PM   #145
DFlores's Avatar
1968 22' Safari
Buda , Texas
Time out for some engine work
Took a few days off of the trailer to assist my son with an engine rebuild, I was really proud of his determination to rebuild and reinstall this engine in such cold weather.
Times are changing, I used to be the guy in charge of the engine work, now that he is grown, I am relegated to the position "sous" grease monkey.
DFlores
David & Diana
Old 11-26-2014, 01:53 PM   #146
DFlores's Avatar
1968 22' Safari
Buda , Texas
The "Screen" Queen
Diane took it upon herself to redo all the screens, since time is getting short. Click image for larger version
ID:	227409Click image for larger version
Note the use of clothes pins to keep her screen in position
The screens in the whole trailer were completed and look really good and tight.
DFlores
David & Diana
Old 11-26-2014, 02:07 PM   #147
DFlores's Avatar
1968 22' Safari
Buda , Texas
Headed Back to the Kitchen
Moving back to the kitchen to pick up some details that were left for later. We are building kitchen drawers.
ID:	227413Click image for larger version
You can tell I am rushing, as my workspace is getting messier as we go.
But we are accomplishing the tasks at hand, the drawer fronts will be stained to match a little later.
ID:	227415Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 02:20 PM   #148
DFlores's Avatar
1968 22' Safari
Buda , Texas
Details...Details
Diane found that she could really clean up the lights over the gaucho with good old Bar Keepers Friend.
Reused the old board and ran wires behind in the groove for lights and thermostat
Lights turned out pretty well.
DFlores
David & Diana
Old 11-26-2014, 02:29 PM   #149
DFlores's Avatar
1968 22' Safari
Buda , Texas
Foam.. Foam.. Foam
Exciting day, we received our foam, had to test fit all the pieces.
Ordered 4 1/2" medium density foam and 1 1/2" soft foam as a topper to get a 6" tall foam piece.
We had made cardboard patterns for the curved bunks and provided dimensions for the straight pieces. We asked that the curved piece patterns be trimmed with an additional half inch all around.
This thing is starting to look like something.
ID:	227420   Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 07:36 PM   #150
DFlores's Avatar
1968 22' Safari
Buda , Texas
Sewing Things Up
Diane working on my dad's old tailoring machine, getting it ready for our next task. We used the cardboard patterns to cut out material for bunks.
The machine is a Singer 3115, quite popular with leather crafters.
ID:	227479   Click image for larger version
ID:	227481   Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 07:43 PM   #151
DFlores's Avatar
1968 22' Safari
Buda , Texas
"Cutting Up" while working inside
I laid out all the pieces using AutoCAD and used the plan to mark and cut out all the pieces we will need for our cushions. Diane labeled everything so we would keep it straight. We are once again working in the kitchen with more tables for layout space.
ID:	227483Click image for larger version
Finally a look at the material we chose for the project.
DFlores
David & Diana
Old 11-26-2014, 07:52 PM   #152
DFlores's Avatar
1968 22' Safari
Buda , Texas
Upholstery
Diane has not done this type of project since she duplicated the "pony" interior for our 1966 Ford Fairlane convertible over 25 years ago.
So here is her first cushion, not bad. We are going with no cording because we want to sleep "all night" and not have to concern ourselves with that cording cutting into our back or side or anything.
Now a look at the curbside bunk bottom, look no wrinkles.
Then she added a back rest for the curbside bunk
Here is a look at the entire front end of the trailer.
DFlores
David & Diana
Old 11-26-2014, 07:57 PM   #153
DFlores's Avatar
1968 22' Safari
Buda , Texas
Zippers go on FOREVER
The zippers for these things are really long, have to be to get that foam into the cover, for that we used dry cleaning bags and a vacuum cleaner.
Here is a look at the three cushion gaucho and another look at the whole thing.
ID:	227492Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 08:05 PM   #154
DFlores's Avatar
1968 22' Safari
Buda , Texas
Meanwhile Back at the Ranch
While Diane is concerning herself with the inside, I am busy installing the propane system under the trailer and sanding and painting the old propane tanks. Installed cut-off valves at each line going into trailer. Reused the old 5/8" fittings for the distribution system, ran into a problem when I attempted to connect the "old" 5/8" lines to newer hoses sold by VTS. Had to order a special 5/8" to 1/2" fitting off the internet, came all the way from California.
ID:	227494   Click image for larger version
ID:	227496   Click image for larger version
DFlores
David & Diana
Old 11-26-2014, 08:14 PM   #155
DFlores's Avatar
1968 22' Safari
Buda , Texas
New Shoes
Installing new tires and wheels purchased from Discount Tire. Went with Sendel 15X6 wheels and Goodyear Wrangler HT's in size 215 75 15, did not want to reduce clearance to body that we achieved thru the installation of the new axle. First picture are the old "working" wheels and tires.
Even though are LT tires, was able to get the warranty that I had read some people had trouble obtaining since they are not trailer tires. Maybe Discount's policy is different.
ID:	227498   Click image for larger version
ID:	227500   Click image for larger version
DFlores
David & Diana
Old 11-27-2014, 06:29 AM   #156
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Happy Thanksgiving! An all American holiday. Your new wheels look great. Sendel is making a lot of very nice trailer wheels. So much better than the old painted black steel wheels with hub caps. Here I prefer the new style wheels over the old.
David
Old 11-27-2014, 09:36 AM   #157
DFlores's Avatar
1968 22' Safari
Buda , Texas
We need a table, but the bulky slide out original design just does not cut it, do not like having to slide into a "booth" to sit at the tableClick image for larger version
Name:	ImageUploadedByAirstream Forums1417102455.732628.jpg
Our solution is a shortened version without the slide, utilizing the original leg on a straight down position
Name:	ImageUploadedByAirstream Forums1417102558.542933.jpg
Trim to match counter top from VTS
Name:	ImageUploadedByAirstream Forums1417102607.637002.jpg
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 11-27-2014, 09:48 AM   #158
DFlores's Avatar
1968 22' Safari
Buda , Texas
Diane has been trying several different solutions for curtains.
Finally settled on a flat pleatClick image for larger version
Name:	ImageUploadedByAirstream Forums1417103304.518995.jpg
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 11-27-2014, 09:50 AM   #159
DFlores's Avatar
1968 22' Safari
Buda , Texas
Turkey Day...anyone else have different ways to cook the "bird"
Name:	ImageUploadedByAirstream Forums1417103402.219740.jpg
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 11-27-2014, 10:19 AM   #160
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You're going to make your goal of 2nd week in December. Congratulations! The upholstery work Diana "whipped up in the kitchen" for your three "gauchos" looks great! And looks very comfortable. Your Safari will sleep three easily. And the little table looks very appropriate. Having those big gauchos pull out into a big bed is a good idea. And the flat pleats Diana made looks great too.
You must post all about your maiden voyage in your new Safari. I expect there will be a long line of folks waiting to see it. Maybe someone will make you a big offer for it. It's worth a lot of $$$. Get it insured if not already.
Me, I don't know how to cook a turkey, except slower it better. I do see you found a good use for leftover Prodex.
David
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 1 02-09-2020 08:28 AM
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 09:47 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 09:31 AM
