09-01-2014, 01:08 PM
#101
1968 22' Safari
Buda
Convection Microwave
Install new Convection Microwave oven, shelf installed to support microwave
DFlores
David & Diana
09-01-2014, 01:10 PM
#102
1968 22' Safari
Buda
Counter Top
Build and install new counter top, used more three quarter inch plywood for top. The new formica laminate is much thinner than I recall.
DFlores
David & Diana
09-01-2014, 01:11 PM
#103
1968 22' Safari
Buda
Cook Top
Install new cook top, picture not so good
DFlores
David & Diana
09-01-2014, 01:13 PM
#104
1968 22' Safari
Buda
Kitchen Faucet
Install new Moen faucet and connect to pex plumbing
DFlores
David & Diana
09-01-2014, 01:15 PM
#105
1968 22' Safari
Buda
Kitchen Sink
New Blanco round sink was built in Germany and under clips are unnecessarily complicated, have to change screws to some with hex head to get torque necessary to install
DFlores
David & Diana
09-01-2014, 01:57 PM
#106
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Awesome job, David!! I cannot wait to see it at Blanco. Very nice workmanship.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
09-01-2014, 03:28 PM
#107
1968 22' Safari
Buda
Thanks Bruce, we are continuing to work towards the Blanco Rally
DFlores
David & Diana
09-28-2014, 12:37 PM
#108
1968 22' Safari
Buda
Overhead Cabinet Stretch
Rebuilding overhead cabinets, copying existing and stretching 1.5 inches to fit the larger refrigerator installed.
Krieg pocket hole jig is invaluable for making new face frames.
This is our first attempt at repairing vinyl covered doors, Diane did an excellent job putting doors back together.
We found that our kitchen table is the most comfortable work area.
DFlores
David & Diana
09-28-2014, 12:42 PM
#109
1968 22' Safari
Buda
Install our first overhead
We drug our new overhead out to the trailer and wrestled into place and used our Krieg screws to lock into place along with #8 sheet metal screws into aluminum skin.
Wired new light fixture into bottom of cabinet and it is starting to look like something.
DFlores
David & Diana
09-28-2014, 12:47 PM
#110
1968 22' Safari
Buda
Refurbish old exhaust fan
Refitted the old exhaust fan after my finishing specialist (Diane) repainted the exhaust fan housing with appliance paint.
Installed new push button switch to replace the old turning type switch, Diane found new magnets for door and cleaned filter with HVAC coil cleaner.
DFlores
David & Diana
09-28-2014, 12:52 PM
#111
1968 22' Safari
Buda
TV Mount on new wall
We installed Cheetah TV mount on new wall and reinforced wall with 3/4" plywood on backside.
New cable wiring from Jack antenna and DVD player along with 120V outlet line up horizontally behind the arm of Cheetah mount.
TV mount will swing around and make TV visible from rear of trailer.
DFlores
David & Diana
09-28-2014, 12:58 PM
#112
1968 22' Safari
Buda
Finding Space for a Pantry
The 1968 came with a control panel reflecting the "Space Race", we decided to revamp this space for our pantry.
Diane continues to be the finish expert, here she is filling my nail holes before staining.
We designed a "cute" set of doors and new control panel that meets our needs along with a small piece of counter top for our coffee pot.
DFlores
David & Diana
09-28-2014, 01:03 PM
#113
1968 22' Safari
Buda
More Pantry Build
The little doors are inside the right side of the pantry giving access to back side of wiring for control panel items.
Working in the kitchen workshop again, we test fit cereal box and cans for shelf height setting.
DFlores
David & Diana
09-28-2014, 01:15 PM
#114
1968 22' Safari
Buda
Pantry Installation
Slipped new pantry into place with new welting around edges, could have left a bit more room for welting, but we got it in.
You can see how the little doors inside provide access to electrical wiring.
On the control panel area we are beginning to put in tank level monitor (Garnet SeeLevel II Tank Monitor)
DFlores
David & Diana
09-28-2014, 01:20 PM
#115
1968 22' Safari
Buda
Finish Control Panel
Completed control panel with installation of Atwood 6 Gallon Water Heater control, 12V system voltage readout and the 120V outlet for the coffee pot.
DFlores
David & Diana
09-28-2014, 01:24 PM
#116
1968 22' Safari
Buda
Diana finds a Kitchen Rail
Diana found a kitchen rail that she really wanted to install in the trailer, problem is that it mount with a slide on installation, and I have to be the one to tell her that it will probably bounce off during movement of the trailer.
So, we came up with this modification to installation, it is now firmly affixed to wall.
DFlores
David & Diana
09-28-2014, 01:27 PM
#117
1968 22' Safari
Buda
Kitchen if Finished
We now have a kitchen, moving on to next element.
DFlores
David & Diana
09-28-2014, 01:33 PM
#118
1968 22' Safari
Buda
Water Tank Installation
We are reusing the old water tank, after leak testing for two days and pouring two gallons of bleach into tanks and holding for the same two days.
Polished around exterior fill cap and polished neck, installed with four stainless steel screws.
SeeLevel tank monitor glued to side of tank.
DFlores
David & Diana
09-28-2014, 01:36 PM
#119
1968 22' Safari
Buda
Water Tank Enclosure
Duplicated water tank enclosure, had to sand to fit around curved doors, even though we cut new doors to match the old doors.
We made vertical wall out of 1/2" plywood instead of 1/4" plywood for added stiffness.
DFlores
David & Diana
09-28-2014, 01:48 PM
#120
1968 22' Safari
Buda
Shurflow Water Pump
Installed Shurflow water pump in the space allotted (1 cubic foot space), we did not have the room to install 36" flexible hoses before and after pump.
Installed 12" braided plastic tubing on suction side and 12" braided steel hose on discharge side.
The Pex over the top if for filling tank from "City" water connection.
DFlores
David & Diana
