05-25-2014, 06:13 PM
#61
1968 22' Safari
Buda
Continuing with updates
Made frame for AC from the channels we made
Reinforced with new channels and Poplar 1x2 in new channels
DFlores
David & Diana
05-25-2014, 06:17 PM
#62
1968 22' Safari
Buda
Really gross pic
Rigged tent for heat, allowing for access to roof, cut off tip of finger with brand new utility blade, trying to get around under my tent
DFlores
David & Diana
05-25-2014, 06:20 PM
#63
1968 22' Safari
Buda
Fantastic Fans
Removed existing vents and cut out hole for new Fantastic Fans
Test fit and remove
DFlores
David & Diana
05-25-2014, 06:23 PM
#64
1968 22' Safari
Buda
Inventive use of holes in roof
Used the three holes in the roof to do first pass on polishing roof, popping up thru ceiling, prairie dog style, we did not have pictures of me poking out the top, sorry
DFlores
David & Diana
05-25-2014, 06:27 PM
#65
1968 22' Safari
Buda
Finally have some kind of lights
Install new LED running lights and new stop turn tail lights
Checked all work, hooked up to my pick up, tested all wiring for stop-turn-tail and running lights
DFlores
David & Diana
05-25-2014, 06:31 PM
#66
1968 22' Safari
Buda
Tearing out old electrical
Diane stripped out old 120 v wiring and 12v interior wiring with bolt cutters, it would have taken me forever, as I would be trying to remember each existing run. She allowed me to start fresh.
Sealed for leaks from inside using Rustoleum Leak Seal Flexible Rubber Sealant after all old wiring is gone
DFlores
David & Diana
05-25-2014, 06:33 PM
#67
1968 22' Safari
Buda
Begin insulation
Install first layer of Prodex insulation, used carpet tape to adhere
Sealed at seams with Silver AC seam tape
DFlores
David & Diana
05-25-2014, 06:36 PM
#68
1968 22' Safari
Buda
Next layer insulation
Install 2” strips of 1/2” thick Owens Corning Foamular from Home Box next to vertical ribs, and about 12” O.C. in between ribs, used carpet tape again, I think I bought over 30 rolls of this stuff
DFlores
David & Diana
05-25-2014, 06:40 PM
#69
1968 22' Safari
Buda
120v & 12v wiring goes in
Install both 120v and 12V wiring over first layer of Prodex, within 1 /2 inch air gap, redesigned electrical layout and moved location of electrical fuse panel, found that Gorilla tape does not hold wiring as well as silver Air conditioning seam tape
DFlores
David & Diana
05-25-2014, 06:42 PM
#70
1968 22' Safari
Buda
More Prodex
Install second layer of Prodex, sealing up wiring and creating ½” air gap, adhere with carpet tape, seal with Silver AC seam tape, we purchased one roll of Prodex and able to easily apply two layers, with some left over for wheel wells
DFlores
David & Diana
05-25-2014, 06:44 PM
#71
1968 22' Safari
Buda
Last layer insulation
Install layer of ½” RMax panel insulation adhered with more carpet tape to fill 1 ½” wall, seal seams with Silver AC seam tape, I hope this will add to sound deadening and possibly add to R value
DFlores
David & Diana
05-25-2014, 06:47 PM
#72
1968 22' Safari
Buda
Another injury - safety warning
Power wash interior skins, Diane found that power washer can go right through your foot, just inside of little toe, but trailer skins clean up very nicely.
Please wear appropriate shoes if you chose to use a power washer
DFlores
David & Diana
05-25-2014, 06:49 PM
#73
1968 22' Safari
Buda
Door insulation
Remove and replace door interior skins and insulation, replace wood frame around L-100 lock
DFlores
David & Diana
05-25-2014, 06:52 PM
#74
1968 22' Safari
Buda
"The Patch"
Previous owner had installed a hasp to lock the door, had to come up with some kind of camo for the damaged area
Came up with this for right half
Completed "Patch"
DFlores
David & Diana
05-25-2014, 06:55 PM
#75
1968 22' Safari
Buda
On to the skins
Install interior skins and trim pieces around windows, many rivets, the large panels that makeup ceiling required help from visitors
DFlores
David & Diana
05-25-2014, 06:59 PM
#76
1968 22' Safari
Buda
Ceiling fixtures
Install AC, new interior lights and new Jack antenna, used dremel to create extra room for cable
DFlores
David & Diana
05-25-2014, 07:00 PM
#77
1968 22' Safari
Buda
Subfloor
Float subfloor with bondo, then sand, sand, sand. Seal with Polyurethane from Home box, in white plastic jug.
DFlores
David & Diana
05-25-2014, 07:03 PM
#78
1968 22' Safari
Buda
Flooring
Install vinyl sheet flooring, bought vinyl sheet tape, seems to be exactly the same as carpet tape we used for insulation installation. Only glued down the single seam. Measure, measure, check, measure, then cut
DFlores
David & Diana
05-25-2014, 07:04 PM
#79
1968 22' Safari
Buda
Water heater is next
Install new 6 gallon water heater, into newly shaped hole in side of trailer, cut from new All Clad sheet from Vintage Trailer Supply
DFlores
David & Diana
05-25-2014, 07:07 PM
#80
1968 22' Safari
Buda
ABS plastic interior pieces
Insulate and install refurbished interior wheel wells, Diane has refurbished all interior ABS plastic pieces, with mesh plastic and PVC glue patches and reinforcement. She developed a real talent for this repair.
DFlores
David & Diana
