06-10-2013, 08:59 PM
#41
1968 22' Safari
Buda
BAL stabilizer jacks and belly pan done
With the completion of the belly pan, the frame flips back over, the new Dexter axle goes on this week. Then the shell drop is back on schedule for June 15
DFlores
David & Diana
06-13-2013, 08:27 AM
#42
Vintage Kin
Fort Worth
The DEE HOWARD Company is worth the time to read on in re fascinating and highly skilled aircraft design and such. They were building out a 747 for the Saudi Royal Family when I was in college in San Antonio. And the HOWARD 500 was the all-time coolest high-speed executive transport ever built in the radial engine era!
Thanks for the updates, congrats on saying the right prayers, and look forward to more!!
06-14-2013, 05:41 PM
#43
1968 22' Safari
Buda
I did put insulation in it
We did put insulation under the floor, 3" of expanded polystyrene, with spray foam insulation between to fill the cracks.
Also, sprayed 1" of foam to cover the heat ducts, the job was not as neat as I had imagined, but it is effective.
DFlores
David & Diana
06-15-2013, 07:44 PM
#44
1968 22' Safari
Buda
Near perfect landing of the Shell
With all the rain we have been having, there was no more delaying the shell drop, we started early with prep work and the help arrived around 10:30 AM, and we are off to the races.
All as per schedule.
DFlores
David & Diana
06-15-2013, 07:53 PM
#45
1968 22' Safari
Buda
Shell down
After nearly 6 months the shell is finally down, nearly perfect, except......
DFlores
David & Diana
06-15-2013, 08:01 PM
#46
1968 22' Safari
Buda
Curb side around wheel well
Looking at the exterior in first photo, the shell looks to need to drop about 1/2" more. The next photo is the rear most rib, which is bottomed out, then the next forward rib behind the wheel well needs to drop, and finally the rib forward of the wheel well, all on the curb side.
I looked for and found the infamous hidden rivet, removed and proceeded but still will not go further down.
DFlores
David & Diana
06-15-2013, 08:12 PM
#47
1968 22' Safari
Buda
Checking for problems
The holes in the door frame line up with holes in trailer frame.
The clecos at the rear all line up with floor channel, the front fits well over the the banana wraps.
Not sure what to think, so I am going to let it set over night, maybe a good nights sleep will relax the shell into place.
If not, I'm going to trim the wheel well and button it up, since there is no buckling on exterior, it looks fine otherwise.
Any ideas?
DFlores
David & Diana
06-16-2013, 05:37 PM
#48
1968 22' Safari
Buda
Put some rivets front and back to hold it together, time to start cleaning up for the wedding, have a trailer load of old flooring, bracing and general junk ready to go to the city dump
DFlores
David & Diana
06-16-2013, 07:14 PM
#49
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Hi David,
Just stumbled upon this thread. Glad things are going well for you. Hopefully we'll see you at a rally soon.
Keep up the good work!
Lance
Lance
06-16-2013, 08:22 PM
#50
1968 22' Safari
Buda
Thanks Lance, we will attend many rallies soon.
DFlores
David & Diana
07-14-2013, 05:15 PM
#51
1968 22' Safari
Buda
Little Help Please
OK, so my daughter is married and honeymooning in Paris, it took one month out of my schedule.
Now can someone look at the attached chicken scratched sketches and maybe give me the best answer for the plywood at the door threshold.
Currently is is as per sketch #1, and the shell does not sit completely bottomed as can be seen in photos within previous post.
DFlores
David & Diana
07-14-2013, 07:05 PM
#52
1968 22' Safari
Buda
Anyone
Can anybody offer assistance?
DFlores
David & Diana
07-14-2013, 07:22 PM
#53
1999 34' Excella
Hillsboro
Has frame shifted?
Peace and Blessings..
Channing
WBCCI# 30676
07-14-2013, 07:26 PM
#54
1968 22' Safari
Buda
No, the holes in the threshold line up with the holes in the frame, you can see in the first picture of post #47.
DFlores
David & Diana
07-14-2013, 08:06 PM
#55
1968 24' Tradewind
1959 17' Pacer
holly springs
, Georgia
David, I don't really know but you would think there should be some wood under the threshold so I vote for #3
07-14-2013, 08:18 PM
#56
1968 22' Safari
Buda
Thanks for your reply, that portion of the floor was completely rotted when we started, so we don't have ant idea how it was originally.
DFlores
David & Diana
07-15-2013, 05:05 AM
#57
Always learning
1972 29' Ambassador
Central
David,
The sub-floor is sandwiched between the frame and the threshold. The three holes in the threshold are what is used to attach this area together. Use 1/4"-20 countersunk bolts there. #3 would be the closest depiction of how it looks, however there are no e-bolts under the threshold. You may have to route out some of the sub-floor to match the profile of the threshold to get a good fit.
Lance
07-15-2013, 04:40 PM
#58
1968 22' Safari
Buda
The Answer
Originally Posted by Top
David,
Thank you Lance, I did some digging and found a picture before I removed shell and also took photo of what it looks like today, you are absolutely right. We will have to route, dremel, rotozip, out a notch like option three to make it set down with no gap.
I was so determined to do a good job on this that I may have gone overboard on the elevator bolts, now will have to do some fancy carving on the head of a couple to get them to slide past threshold.
DFlores
David & Diana
08-04-2013, 01:53 PM
#59
1968 22' Safari
Buda
Wedding done, Honeymoon over, back at it
I was able to lift shell just enough to slide threshold over to make notch for shell to settle in.
Used an attachment for my Dremel that cuts 1/4" deep, so we cris-crossed the needed notch with cuts then, went at it with a wood chisel until I had it defined really well.
Changed to wheel in the Dremel to cut the head of elevator bolt and finally a coat of marine epoxy.
DFlores
David & Diana
05-25-2014, 06:10 PM
#60
1968 22' Safari
Buda
Have not updated in some time
DFlores
David & Diana
