RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-28-2018, 07:32 PM   #1
1968 22' Safari
Jamul , California
City water
I'm plumbing my 68 Safari from scratch and I need some information on how to attach city water to my pex plumbing. First, do I need to install a ball valve to close off the city water line when not in use? Second, do I need to put a pressure regulator in that line and if so, could anyone recommend one? If anyone has pictures of how theirs is set up that would be appreciated. Thanks
Name:	irma airstream.jpg
bsaa10bill is offline   Reply With Quote
Old 07-28-2018, 08:00 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use an external pressure regulater. Easier to replace than one hard piped.
Most city water connections have a built in check valve which fail from time to time.
A ball valve to shut it off is not a bad idea.
As well as one to prevent back feeding the onboard pump.
Old 07-28-2018, 08:05 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
What fits or does not fit will dictate what you can use. A pressure regulator *somewhere* is a needed part of the system. If you don't put it in the trailer, it will have to be on the hose each time you hook up. There are advantages to each way. The belt and suspenders approach is to do both.
A ball valve for disconnect is not normally part of the setup. A back flow prevention valve ( so you don't get sprayed disconnecting ....) often is part of the setup. It also lets you use the water pump without capping the city water input ( = yes use the back flow valve ).
So: Most simple answer - no regulator / no valve / no back flow, just hook it with a hose connector. (and cap it every time you are "done" .... uggg ....).
Most fancy answer - adjustable regulator / back flow / fancy hose connector
Old 07-28-2018, 09:04 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I plumbed with pex and used residential fixtures, I don’t use a pressure regulator. I installed a check valve just north of the trailer entry, but I also put a plug in when I’m not hooked to city water.
Old 07-28-2018, 09:54 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used residential fixtures as well.
Connected sinks, toilet and water heater with stainless steel braided hoses. Makes for easy connections etc.
Old 07-29-2018, 02:29 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Where I store my trailer the water pressure is often over 100 psi. Never any problems.
Old 07-29-2018, 08:28 PM   #7
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I will use an external pressure regulator.
The picture is before tank drain was put through the floor & before the fill tube for the tank was in place.
After I hooked it all up I tested the city side/tank sideClick image for larger version
ID:	318381, no leaks & no problem with back feeding the pump.
Hope this helps.
In the photo the check mark with the word valve is a check valve.
I was going to mount the pump vertically but ended up mounting it to the floor.
The pump can be mounted either way.
Dingo Girl is offline   Reply With Quote
Old 07-29-2018, 08:48 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Too bad A$ and others don't have your pride in workmanship. Along with future access and maintenance in mind.
Looks Great!
Old 08-03-2018, 04:29 AM   #9
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thanks Twinkle!
Old 08-03-2018, 04:30 AM   #10
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Oops. Twinkie. Auto correct got me again.
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 10:25 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 04:07 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 04:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 02:23 PM
Connected to city water...NO WATER! Sovereign86 Fresh Water Systems 7 06-13-2007 01:00 PM
