Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 02-17-2017, 07:40 AM   #1
1968 22' Safari
Milwaukee , Wisconsin
68 Safari refrigerator
We have a 68 Safari the refrigerator does not work we would like to take it out or fix it is that even an option. If we take it out can we sell it and would anybody like it just trying to get some ideas.
Missmarlay is offline   Reply With Quote
Old 02-17-2017, 08:17 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Unscrew the burner head, blow out the rust particles from the orifice and reinstall and the fridge may work again.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 02-17-2017, 08:25 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
Do a google search from outside of the AirForums and look for search terms like "refrigerator troubleshooting." I know there are some detailed threads here describing the steps to go through to troubleshoot RV refrigerators.
The problem could be simple, ie., the electrical heating element not working, and a cheap and easy fix ($50). If the coil has allowed the ammonia gas to leak out, then the fridge isn't worth fixing, and its only value may be in a few of the plastic parts.
If you have pulled the refer out of the trailer, put it on a nice level surface, plug it in and turn it on in electric mode for max cooling. You will have to wait around 24 hours for it to feel very cold inside. The electric part of the cooling mechanism is just a heating element that is installed in part of the piping in the back. If you can feel the piping getting hot after a couple hours, but the fridge is not getting cool in 24, then you have probably lost the gas from the system, and you need to consider seriously if it is even worth fixing (replacing the cooling core will cost about half of the price of a new fridge). If the piping in the back is not getting warm, then either the heating element is shot, or wiring, thermostat, etc., is. At this point, try attaching it to a propane bottle and lighting the fire and running it in propane mode. If it gets cool, then great, it might just be a minor electrical problem, if not, then, again, you've lost your coolant.
If you decide to repair it, have a good look at the rubber seal around the door and the condition of the interior. If the seal is shot, and you have cracks in the interior and missing shelves, then you still may be looking at a lot of expense to getting it working well.
good luck!
Old 06-26-2017, 01:08 PM   #4
1967 22' Safari
Elkton , Maryland
Thanks for your suggestions from this Safari owner. I'm going to give them a try. If the problem appears to be severe enough to warrant a replacement, then I'll have to wait until my hubby can help me, as he has had recent arm surgery.
Getting tired of bringing coolers and having the daily ice runs when I could have a functional refrigerator.
NJ Amanda is offline   Reply With Quote
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
Switch above refrigerator in 67' safari Adair Lights - Interior & Exterior 4 01-04-2008 09:18 PM
Burner for a refrigerator Safari 1964 jpsabourin Refrigerators 6 06-23-2007 02:36 PM
73 Safari Refrigerator kneal Refrigerators 3 01-02-2007 06:08 PM
New Refrigerator for 1971 Safari? Larry71 Refrigerators 13 03-14-2006 09:38 AM
