Old 10-08-2015, 09:11 PM   #1
1965 22' Safari
tempe , Arizona
Rivet Wheel Hub Seal
How do I get the seal out so I can grease the bearings. The trailer has been sitting since 1971.
smokey 8866 is offline   Reply With Quote
Old 10-08-2015, 09:27 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Waterpump pliers with a grip that will fit the cup. Grab it tight and wiggle it loose. PB Blaster, carb cleaner or brake cleaner will loosen the cup too. You can use those fluid also to clean the bearings and races. Inspect the bearings for rust damage.
Old 10-09-2015, 12:54 AM   #3
Mission , Texas
Here you go ...
nrgtrakr is offline   Reply With Quote
Old 10-10-2015, 05:54 PM   #4
1965 22' Safari
tempe , Arizona
Thank you
Hub "cap" and bearing seal missing Landmammal Wheels, Hubs & Bearings 4 11-12-2011 06:54 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Hub Greese Seal Price Shock Cracker Axles 11 06-06-2004 07:51 PM
