River Rat I just installed a Pinguin II on my 65 Safari , at the center roof vent. You will find the 120 vac wire there, also mine had a 14/2 wire that I think was for a thermostat if used. Also I replaced the breaker box to add another 20 amp breaker. Mine did not have a drain installed ,but I was able to run one through the cabinet over the refer. The job took me less than a week , and half a day to build a scaffold above the trailer. Good luck any thing I can help you with let me know
The St Pierre's
