RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-30-2014, 11:56 PM   #1
1971 31' Sovereign
1973 29' Ambassador
Palm Desert , California
Water valves and underbelly tubes
I have the service manual for a '72 but it doesn't go into detail about what the water valves do in the different locations. It also doesn't say where all the tubes exiting the bottom come from.
Has anyone made a list somewhere I haven't found yet? I have 3 under the galley, one by the hot water heater in the cabinet and 2 or three in the rear by the battery.
For example, looking under the trailer today on the curb side, midway just under the wrap, I saw a rubber hose that was disintegrating. I have no idea where it comes/goes or what it does.
Thanks. Any help is appreciated.
CaCraig is offline   Reply With Quote
Old 12-31-2014, 07:41 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings CraigCA!
Welcome to the world of Vintage Airstream ownership!
The valves that you are seeing on the water supply lines are likely low point drains that are utilized when winterizing -- there likely will be one for the hot water lline, cold water line, and water filter line below the kitchen sink. The. Rear compartment likely has hot. And cold low point drains for the sink and bathtub as well as one for the toilet line. You will also likely find one or two low point drains near the water heater. You will also likely find drain tubes through the belly pan for the air conditioner condensate drain and a drain tube for the fresh water tank.
Good luck with your Airstream.
Kevin
Kevin D. Allen
AIR #827
Old 12-31-2014, 11:00 AM   #3
1971 31' Sovereign
1973 29' Ambassador
Ahh. I was thinking the one near the hot water was for the toilet but maybe the one for the toilet is in the rear compartment. Sometimes the copper lines disappear under the floor or behind a wall so they can't be followed.
Here is a picture of the underside with the rubber hoses that are falling apart. I'm not sure if they are there to protect the line as it enters the AS or if they actually carry something.
Old 12-31-2014, 02:01 PM   #4
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings CraigCA!
Sometimes, Airstream used rubber hoses to protect the metal propane lines from road debris -- this has been discussed on the Forums in the past, but it doesn't seem to apply to all trailers or all years (I don't believe that my Over lander or Minuet came with these protective covers).
Good luck with your investigations!
Kevin
Kevin D. Allen
AIR #827
Old 12-31-2014, 03:19 PM   #5
1971 31' Sovereign
1973 29' Ambassador
That's what I thought too.
Do all the LP gas lines run under the underbelly skin?
Old 01-01-2015, 11:56 AM   #6
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
The propane trunk is under the bottom of the trailer. It branches, goes up to the appliance where the individual line shut offs are located.
beatrix1 is offline   Reply With Quote
Old 01-01-2015, 06:38 PM   #7
Jim&Teach
1976 31' Sovereign
Portage , Indiana
Keep up with pictures. Very helpful. Just bought a '76 Sovereign this summer. Jim&Teach.
jimmbob is offline   Reply With Quote
Old 01-03-2015, 11:21 PM   #8
1971 31' Sovereign
1973 29' Ambassador
jimmbob-Did you buy the owners and service manuals?
Phase 2 has started, new kitchen cabinets and front underbelly, floor and restoration aquinob General Interior Topics 68 05-15-2020 12:50 PM
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 07:07 AM
Wheel saga -tubes and flaps hertfordnc Wheels, Hubs & Bearings 25 04-30-2011 12:24 AM
Color temperature and color rendition index of fluorescent tubes Jammer Lights - Interior & Exterior 3 08-16-2010 09:29 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 05:01 AM
