RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-26-2015, 01:31 AM   #1
1971 31' Sovereign
1973 29' Ambassador
Palm Desert , California
Water pressure on city water Q
Is this line (the one after the water pump supposed to be under pressure when on city water?
I had put a regular vinyl hose on here and when I pressurized the trailer with city water I noticed this short line expanded like a balloon, but didn't burst.
CaCraig is offline   Reply With Quote
Old 08-26-2015, 03:04 AM   #2
2007 22' International CCD
Yep. One city water check valve is usually part of the pump. City water pressure comes from the hose inlet, through a check valve that's part of the inlet, through a 60 PSI fixed pressure regulator then splits toward the pump and the rest of water system.
The check valve inside the inlet fitting keeps the pump from dumping water overboard. The pump check valve keeps city water from going backwards through the pump and filling your fresh water tank.
This all assumes your AS is Plumbed in the standard manner.
I'd suggest using tubing that can handle more pressure. I also use an adjustable external pressure regulator to protect my white city water hoses and the rest of my plumbing. I set it to about 30-40 PSI. It's a good idea in any case. Don't use a cheap in line external regulator. It screws things up on low pressure, and makes you think your expensive tankless water heater is malfunctioning. Don't ask how I know this...😄
Old 08-26-2015, 08:49 AM   #3
1971 31' Sovereign
1973 29' Ambassador
What kind of external pressure regulator do you use? I just barely opened the spigot and had a lot of pressure in the AS. I think the original regulator isn't working.
Old 08-26-2015, 08:53 AM   #4
Mission , Texas
For some reason I remember 30 psi being ideal, so when I replaced my regulator that was the setting. Shower is fine.
nrgtrakr is offline   Reply With Quote
Old 08-26-2015, 08:55 AM   #5
dznf0g's Avatar
Oswego , Illinois
I use a watts external regulator set at 50psi.
-Rich-
Old 08-26-2015, 02:23 PM   #6
It's an adjustable regulator with gauge from Camping World. Don't remember the brand.
Old 08-26-2015, 04:37 PM   #7
Zil
Curtis Wright
Eyren Haven , South Jersey
City pressure from a hose bib should only be around 60 psi. Or even 70 that type hose should be fine. You are talking about cold water?
Zil is offline   Reply With Quote
Old 08-26-2015, 06:42 PM   #8
Yes. Cold water. I've seen ridiculously high pressures in campgrounds. I basically don't trust their pressure and want to protect my hoses. I like gauges so I know what's hitting the AS.
Old 08-27-2015, 08:34 AM   #9
1971 31' Sovereign
1973 29' Ambassador
I tested the spigot where I was getting the water from and it's 60psi. I still think ill pick up an external regulator so I can set it lower.
The braided hose is holding up fine at 60psi.
Old 08-27-2015, 10:54 AM   #10
dznf0g's Avatar
Oswego , Illinois
I was at a CG in Rock Island a couple weeks ago. Spigot psi was 85!!!!!!
regulators are a necessity in my book.
-Rich-
Old 08-27-2015, 04:24 PM   #11
I'd love to find one with a gauge on the input as well as the output, but i settled for one on the output because that's the important one.
pump configuration for optimal pressure on city water 72streamline Fresh Water Systems 5 02-18-2014 02:58 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 10:25 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 04:07 PM
Replaced city water SHURflo pressure relief valve fitting silverback Fresh Water Systems 3 06-01-2010 02:32 PM
no pressure when connected to city water tombhs General Repair Forum 8 06-28-2009 02:07 PM
