I need to replace the original Univolt with a converter and separate fuse panel. My trailer is rear bath with the Univolt located behind the curbside tub. My question is this: Where should I install the fuse panel? It seems that the closet wall forward of the tub is the best location, but I don't know.
1971 31' Sovereign
1973 29' Ambassador
Palm Desert
On my 71 with a rear bath I put the new converter right where the Univolt was and the fuse panel right inside the hatch door next to the new converter.
Thanks CraigCA...How did you secure the fuse panel in that location? Also, do you have access to individual fuses without pulling out the entire panel?
1971 31' Sovereign
1973 29' Ambassador
Palm Desert
Sorry, I meant to post this yesterday. I have an access door on the curbside behind the twin bed for the Univolt. I mounted the fuse panel just inside the door.
