12-01-2010, 08:14 PM
#41
1981 20' International
Shasta Lake City
Paint samples today...
12-03-2010, 12:55 PM
#42
Shasta Lake City
The bunny picked the lighter of the two colors....Gold Coast. Trex
12-03-2010, 01:16 PM
#43
1967 24' Tradewind
Greenville
, South Carolina
Rex,
That's the one that Vicky picked too.
12-04-2010, 01:04 AM
#44
Shasta Lake City
Two steps forward....three steps back
Today I removed the pannels that I had painted with a coco colored latex. The pannels are the orginal photo print over plywood. The paint I used was not drying, and the primer and paint was not adhering to the pannels. So its time to step back and redo some of my work....
So, it looks like I will buy brirch hardwood 1/4" plywood at Home Depot or Lowes, both are $28.00 a sheet, and use the old pannels as templates.
The light colored paint, (Gold Coast), looks good, drying well, and I think will last a long time. So far, no signs of Plasticizers, (sticky Walls).
Trex  "May Wally be with you."
12-06-2010, 01:42 AM
#45
Shasta Lake City
Looking at Craig's list
I was looking at Airstreams on Craigs list and came across a Streamline TT, and a Travellux both look to be mid to late 60's models. If you'er interested look under Vancouver BC Craig's list. Trex
Here are the Pics....
12-21-2010, 07:16 PM
#46
Shasta Lake City
New water lines and wast lines
12-21-2010, 07:48 PM
#47
Shasta Lake City
I wanted to add that my friend Porno Bob, who is a plumber by trade, came by and adapted the old copper line over to Pex plumbing fittings. Thanks Bob... Trex
Bob with my girl...Bunny at Herford Ranch RV park in the Lassen Park Area east of Redding.
12-22-2010, 06:46 PM
#48
Shasta Lake City
Installed new pannels
Today I installed two of the new pannels, on the right in the photo. I used the old pannels as templates to cut out the new cabinet grade 1/4" birch plywood. As you can see in the photo, the pannel on the left is the last of the old "photo wood plywood pannels." I plan to remove tomorrow so I can cut out the new pannel for that side. So, what do you all think folks?
Trex  May Walley be with you....
12-23-2010, 07:22 PM
#49
Shasta Lake City
One pannel at a time....
I wish I had more room to work on the cabinets.... anyway I cut out and stained a new rear left pannel. It stopped rainning today so I was able to work outside when I was cutting the pannel and the diamond plate today. Once I got it stained, I finished installing the closet on the right side... I installed the old door because I wanted to make sure the pannel was installed in the correct location. I will remove the door at a later date and replace will 1/2 birch plywood, I think it will fit the orginal door frame? Has anyone ever done that... Also cut diamond plate and installed in closet as flooring.
I am using the diamond plate as flooring inside the cabinets, and under the sink and oven. It may be a little bit "Over Kill" but the way I am going to construct the cabinets, the trailer floor will also be my cabinet floor.
Trex
12-23-2010, 08:52 PM
#50
Shasta Lake City
More Photo's
12-25-2010, 02:46 PM
#51
Shasta Lake City
Merry Xmas
Merry Xmas Streamers!!!! All I wanted for xmas was a Walley World Tee shirt and a Airstream xmas omament.... life is good. Trex
12-28-2010, 12:33 AM
#52
Shasta Lake City
Found some thin, (1/16"), plastic vinyl sheeting for the shower/tub at Home Depot...used contact cement to glue to new pannel. Then installed the left rear pannel today using the original trim.... cut out and sanded the next pannel to be installed once it is stained.
Trex
12-28-2010, 12:57 AM
#53
Shasta Lake City
More pics
Here's more photo's of todays work.....showing how thin the bathroom sheeting is, and how it looks in the bathroom.
Trex  "May Walley be with you"
12-29-2010, 07:12 PM
#54
Shasta Lake City
Floor inside the cabinets
Today I stained two more pannels with clear "brush on" Deft, and cut more diamond plate... which will be used as the floor inside the cabinets on the street side of trailer.
12-30-2010, 09:00 PM
#55
Shasta Lake City
Pannels and floor
Today I cut diamond plate and mounted the new fresh water pump (3 gallon per minute). Sanded and put a 3rd coat of stain on the two pannels.... Trex "May Walley be with you"
12-30-2010, 09:57 PM
#56
Shasta Lake City
Old photos of same area
Here's some old photo's of what I found, under the old cabinets when I started the remodel....
Trex
01-02-2011, 03:03 PM
#57
Shasta Lake City
Cabinet framework
Happy New Years Streammer's..... Last day of the year and the Bunny is cooking a Prime Rib and I am out in the Old Girl installing two more pannels and started installing the alum. framework for the kitchen cabinet. I added one more pannel on the street side, so the countertop will be approx. 18" shorter than my original idea. But more storage space for pots and pans is a good thing. I am thinking of using one of the rear original cabinet doors as the bathroom door. I will replace the dark photo wood with some 1/2' cabinet grade plywood for the bathroom door. I took one apart last week and it looks like I can replace the old stuff. Has anyone out there ever try this idea? I know some of you think that I am crazy for installing diamond plate on the floor....but no one is saying anything?
01-02-2011, 04:07 PM
#58
x
XXXX
, XXXX
Hey Rex It's looking great. One question though if the framework you are installing is for the kitchen cabinet. I don't see and space for a bedroom. Do you plan on sleeping standing up in the space behind that bulkhead with the aluminium framework or is it that you are such a party animal that you don't sleep. LMAO.
BTW the diamond plate looks fantastic. How do you plan to keep things from sliding around inside the cabinets? The plate will be very slick. You're not crazy. Remember insanity is only a state of mind.
Chris.
01-02-2011, 05:15 PM
#59
Shasta Lake City
Losing the Ozzie bed
The two twin "Ozzie and Harriet" beds are gone... we will have a 44" wide "twin" bed that will fold down to diner seating, on the crub side (6'5"x44"). Plus we are buying a full queen "hide-da-bed" sofa for the front living area.
The diamond plate doesn't seem to be slippery, and I didn't want to have a double floor under the sink/oven. Plus, I think I could put rubber mats inside, if there were any issues with things sliding around under the cabinets.
But I am trying to use all the old hardware/framing/trim...just adding new wood 1/4" pannels.
So....the old girl will sleep 4, if you don't mind spooning. Trex
01-03-2011, 07:21 PM
#60
Shasta Lake City
Continue framework
Today I continued installing the framework for the kitchen cabinets. And cut more diamond plate for the kitchen pantry...
Trex "May Walley be with you."
