03-02-2011, 12:07 PM
#261
1981 20' International
Shasta Lake City
Originally Posted by Top
Looks great Rex!
Thanks TOP....Trainer of Personnel. Today is a day off from my outside cabinet shop, (front driveway), because of heavy rain.
I got a tip about a trailer yesterday from another member. I called last nite, and going to look today. Owner didn't have much information on the trailer, but based on the photos posted, it looks like a 54 or 55 Sarfari 22". Should be able to get the age of the trailer, if the vin number is still in place.
03-02-2011, 12:54 PM
#262
1967 24' Tradewind
Greenville
, South Carolina
That trailer
Rex,
and anybody else that is interested. I have pics of that trailer that I could send you, more $$$ to get it shape than I have right now though. It's a major project, very cool though and if not for my current project probably would have tried to get it.
03-02-2011, 02:38 PM
#263
Shasta Lake City
Originally Posted by SilverHoot
Rex,
Its a 1954 Sarfari as per vin# O- 6035...so it was the 35th Safari made that year in Ohio.
The trailer has three broken windows, small dents in three corners, rotten plywood floor, replaced vents on top but after market, the fridge and heater are original. Not much of the original interior left. Shower added to the watercloset, half of the dinette set is missing.
Major cut/dent in outside skin on the crubside above wheel well, and no title/pink. Looks like there is a alum. patch on outside skin behind each wheel well.
I made an offer, but the lady/owner thinks it is worth more than I offered. She said, she would call me once she goes to DMV to clean up the paperwork.... I'm not holding my breath on this one.
Like you Mr. Hoot, I have my hands full right now with the Old Girl. But for some reason I knew that you had been here before me.....
03-03-2011, 07:44 PM
#264
Shasta Lake City
Today I continued working on the diner booth... cut 1 1/2" angle aluminum to use as structural support. Cut and removed another small section of Allure Flooring under the right side seat, I will replace with diamond plate. Slow going, but moving forward, and that is always a good thing.
03-04-2011, 01:19 AM
#265
1975 Argosy 26
1963 24' Tradewind
Seattle
I like that pocket screw guide.. I've been searching, something like that or the Kreg. I like the idea of the pocket screw... just have to go get one!  Well, and get the guts to gut my Argosy and rebuild the cabinets and the seats.
I kinda had to chuckle when looking at all those framing squares in the shots. I KNOW Airstream didn't use anything like that when they "built" the cabinets and the dinette in my Argosy... "just get it looking about right" was their motto I'm sure!
Marc
03-04-2011, 12:28 PM
#266
Shasta Lake City
Marc
Mr. 3.... You're so right about the original cabinets, not being very straight. But, what can you do, "It is, what it is". Also, the walls around the wheel wells are very uneven, on the street side the trailer wall bows out almost an inch.
I learned alot from building the kitchen cabinet, (9 1/2' long countertop)...I had to do alot of readjustments to the aluminum frame work, once the countertop was put in place. Hopefully, I won't make the same mistakes on the crubside.
Your photo, was that taken in Westwood, Calif? They have a Paul and babe statue in their city park just like that...
03-04-2011, 08:40 PM
#267
Shasta Lake City
Continued working on the Diner today... Using 1 1/2" alumimun angle and 3/4" plywood, I completed the inside supports for the diner seats. Looks like it may rain thru the weekend, so I got everything I need for tomorrow's task, cut out.
03-04-2011, 11:24 PM
#268
1975 Argosy 26
1963 24' Tradewind
Seattle
No... I tried to stay out of Westwood... Trojan you see!  No, the pic was from the Redwoods... right across from the Dinosaur museum with the pink Brontosaurus!
I like the dinette...
Marc
03-05-2011, 12:53 AM
#269
Shasta Lake City
More pics of today's work... it's hard to believe, but I used more than 40' of 1 1/2" angle alumimun for the diner framework.
03-05-2011, 06:58 PM
#270
Shasta Lake City
Today I cut out the rest of the Allure flooring under the left side bench/seat. Replaced with diamond plate, and did some minor adjustments to ensure both seats are in alinement with each other. Going to a pot luck dinner, so I must sign off....
03-07-2011, 05:57 PM
#271
Shasta Lake City
Today I sanded the side sections of the diner booth with some 220 grid sandpaper... then brushed on two coats of natural color stain, (Deft).
Plus, here is a photo of the 4” polyfoam, I'm using to upholster the seat cushions.
03-07-2011, 07:02 PM
#272
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Looks good Rex. I used Defthane on my floor boards. They make some good stuff. Nearly all the Aircraft paints we use are from Deft or Henkel coatings.
Lance
03-07-2011, 09:11 PM
#273
Shasta Lake City
Thanks TOP....Trainer of Personnel. That's good to know, concerning the Deft stain. I like it because you can brush it on, and the 2nd coat melts into the 1st, (the wonders of a chemical reaction).
In the PM, I started the trim work for the 1/4" plywood front-foot-kick, for the diner....
03-07-2011, 09:15 PM
#274
x
XXXX
, XXXX
That's really coming together nice Rex. A cosy little dinette built for two. How much room do you have between the two seats? It looks a little small in the pics.
BTW what happened to the lobster claws? LOL.
03-07-2011, 09:40 PM
#275
Shasta Lake City
Hey Mr. Was... looks like you're moving right along with your buffing project. When you stop in Redding on your big "drive-about"... you can buff out the Old Girl to a shinny sheen.
The foot space is a little tight, but I only had 7 feet to work with. The bigger issue is the wheel well, (it takes up alot of space), but I think it will work for us. floor space under the diner is 28" x 13", so you would have one foot in the hallway and one under the table.
03-07-2011, 10:45 PM
#276
1963 16' Bambi
Stevens Point
, Wisconsin
TRex,
What kind of fabric do you and The Bunny have in mind for the cushions? Although the foot room seems small, I think it will work out. You just end up sitting with one foot in the isle. Ours is a little crowded, my wife just makes me sit outside at the picnik table!
Just watched the 10PM weather, looks like you have more rain coming. We are expecting 8 inches of snow. The weatherman says it going to be wet and heavy like mashed potatos. Yahoo!
Check with The Bunny first, but I think if you would wear your red socks with the flip flops they would really look like lobster claws. Have a good one.
Tim
03-07-2011, 10:52 PM
#277
Shasta Lake City
They're not lobster claws, Mr. Was....they're crab claws!
03-07-2011, 11:08 PM
#278
Shasta Lake City
Originally Posted by Beaker63
TRex,
Tim
You funny guy Mr 63, I think The Bunny wants Red leather or Red Vinyl, to give it that retro-diner look...I would be okay with the left over Tommy Bahama fabric, (The stuff we used for the sofa). But I do think that red cushions would make that area "POP"! Like this pic off the web.
03-07-2011, 11:41 PM
#279
Shasta Lake City
TRex,
Tim
Maybe I could get some red socks at the dollar store....what would the Dude do in this case? Enjoy the mashed potatos 63!
#280
1973 31' Excella 500
Spring Green
, Wisconsin
Diner is looking good, Rex. Especially like the lacquer finish you're using. That is a really good product.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
