07-03-2011, 05:00 PM
#161
moderator
2016 27' International
Wilton
Amazing... great progress. Will it be ready by labor day?
lol..
Vinnie
07-03-2011, 05:48 PM
#162
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
lol..
Vinnie
Didn't specify a year?
Haha thanks... My sister wanted to know if she could hang a hammock in it and move her potting table under it. I said no.
07-04-2011, 01:20 PM
#163
moderator
Wilton
Well if I said 2011 nobody would doubt it..
07-04-2011, 02:34 PM
#164
1972 31' Sovereign
Wesley chapel
Thanks, I work really fast but without adult supervision I keep redesigning and adding gizmos to the point I never get done. There must be a medication for that
07-04-2011, 02:44 PM
#165
1972 31' Sovereign
Wesley chapel
My cast "international" badges and the cast trim beside them are structurally corroded and beyond repair.
I
Removed the two horizontal trim strips that frame the badge and have decided all of it is being deleted in favor of a cleaner look like the older AS
07-04-2011, 04:27 PM
#166
1972 31' Sovereign
Wesley chapel
Stripping black crap off the walls
07-05-2011, 09:51 PM
#167
1972 31' Sovereign
Wesley chapel
UFO shot
07-12-2011, 08:47 AM
#168
1972 31' Sovereign
Wesley chapel
Well iv been in a steel holding pattern but good news it will arrive Thursday!
My local( 40mi) steel supplier is delivering for free and they are cutting all pieces to length based on my cut list. At $2 a cut that's a he'll of a deal.
07-12-2011, 09:04 AM
#169
1972 31' Sovereign
Wesley chapel
I figured based on material that my factory frame weighs 528lb - rust + rat poop
A C5 @6.7lb frame should weigh 1155lb
Mine will be close to that but my frame rails are taller and some reinforcement around the battery compartments
07-14-2011, 12:56 PM
#170
1972 31' Sovereign
Wesley chapel
Steel just arrived!
07-15-2011, 02:00 PM
#171
Sunset Beach
, North Carolina
Dark, What are you using for cross-members and outriggers. I was researching that and found that a metal fabricator could bend up some 11 gauge plate for around half the cost of the factory crossmember replacements.
I am not sure if I saw a post on the weight differences of C Channel steel, but the web site below, says that 1/8 plate is 5.112/sq. ft. A linear ft of plate is about .7 sq ft, so to cut to the chase the difference per foot of plate/stock is about 3# foot....u may want to validate as my second grade math is being tested to its limits.
How much does a 1/8 steel plate weight per sq.ft.? - Yahoo! Answers
07-15-2011, 02:33 PM
#172
1972 31' Sovereign
Wesley chapel
07-15-2011, 02:42 PM
#173
1972 31' Sovereign
Wesley chapel
My cross members are two 2"x 3" 3/16 L sections. One above the other forming a C with a gap between them for wiring etc... Creates a boxed ladder structure. Outriggers are a single 2" x 3" 3/16 L this gives me a 2" face for mounting the decking
My frame is going to be a little overkill to take the weight of additional batteries.
07-15-2011, 03:01 PM
#174
Sunset Beach
, North Carolina
Can you expand on the weld process? Will you be posting each step...hint hint. Are you going to use stick? I was going to marry the original C with stock 3/16 C channel on mine. I am not sure if me and a stick welder is the ticket..maybe something more potent???...definitely not my little 115v flux core. I will probably farm out the welding, I am not very comfortable assembling a 7K pound rolling liability.
07-15-2011, 03:36 PM
#175
1972 31' Sovereign
Wesley chapel
Stick is good but it is difficult to tack members together before yo go in and do all the final welds. Mig is better for this type of work I use a 180 C Lincoln with intershield wire as I am working outside
07-15-2011, 03:38 PM
#176
1972 31' Sovereign
Wesley chapel
I will post as I go
07-15-2011, 04:51 PM
#177
1972 31' Sovereign
Wesley chapel
If you decide to weld these really help. Called " strong hands " each side has a magnet and it can be turned on and off
07-16-2011, 07:43 PM
#178
1972 31' Sovereign
Wesley chapel
Ok before you freak out.... its a special use frame...
Today was my first day of tacking up the new frame.. I will go back and seam weld everything once I know everything is in the correct place.
Before everyone freaks out this is a special use frame designed to support more weight than your average AS. The additional weight will be from a large Solar / Battery addition.
Tomorrow I will be tacking the outriggers. Today was just the boxed ladder frame.
The main frame rails are 2" x 10" Rec. Box
Cross members are 2" x 3" L
Outriggers are 2"x 3" L
07-16-2011, 09:15 PM
#179
moderator
Wilton
No freaking out here.. That box frame is overkill and a nice addition to the airstream. Have you seen this setup used before or did you just dream it up?
Vinnie
07-16-2011, 10:35 PM
#180
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Looks BEEFY! Interesting. Can't wait to see it completed!
Lance
