10-08-2011, 09:30 AM
#241
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
I'm days away from 'game on' watching the ups boxes pile up.
10-08-2011, 09:36 AM
#242
1972 31' Sovereign
Wesley chapel
The 3M guy is sending me samples of a ceramic coated mirror window film that has some insulating properties. The idea of mirrored windows on a polished airstream seems interesting.
10-08-2011, 10:47 AM
#243
Master of Universe
2008 25' Safari FB SE
Grand Junction
Mirrored windows means birds will be flying into them.
Gene
10-08-2011, 11:07 AM
#244
1972 31' Sovereign
Wesley chapel
Gene
How does a bird locate the mirrored window on a polished airstream?
10-08-2011, 11:59 AM
#245
Master of Universe
Grand Junction
The bird sees his reflection in the window and flies toward it and hits the window. On residential windows with a coating on the outside this happens frequently. The bird may think the reflection is an interloper or a friend in the same flock. Energy efficient windows usually have this coating. We have put images of hawks in the largest windows to scare the birds away from the windows. It helps, but is not foolproof. The birds may be stunned, may be killed, or may just fly away. Cats love these windows. The hawk images are available at some stores and stick on the windows. I think you just have to dampen them to stick.
Birds may see an image in a polished aluminum surface, but it will be distorted by the curves and is probably not the problem a mirror like surface of a window is. Because the Airstream windows are small, this may not be as much a problem as it is with residential windows.
Gene
10-08-2011, 01:02 PM
#246
Vintage Kin
Fort Worth
Around here it is the Inca Dove which hit our house windows. Sometimes we hear it, sometimes not. Rarely find a bird afterwards. But the distinctive markings show up "embossed" on the window.
Looking forward to what you learn about the film. What about night-time reversal, where interior light and exterior dark seem to occur with greater contrast than uncoated windows? Or, is this my imagination?
10-09-2011, 12:46 AM
#247
1972 31' Sovereign
Wesley chapel
Insulation plan and cost so far:
3 gallons of SuperTherm for the roof $300
10 gallons of HSC1000 ceramic for the inside surface of the exterior skin and rib faces $550
1200 board feet of E84 closed cell foam - 2" thick in walls $1400
24"x 50' 3m solar film mirror / grey $200
This is where I'm going to stop and do some testing before considering an additional thermal break between ribs and interior skin.
10-09-2011, 09:45 AM
#248
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
We are all awaiting your test results with eager excitement!
Lance
10-09-2011, 10:36 AM
#249
Tool Hoarder
West
Damn and I am just gonna use Prodex....
10-09-2011, 10:57 AM
#250
1972 31' Sovereign
Wesley chapel
Well il be the guinea pig on this one. I have used these to insulate steel shipping containers with great results so besides the aluminum conduction issue it should work out. Il park mine beside another 31' in the sun and do the pepsi challenge.
10-09-2011, 11:06 AM
#251
1972 31' Sovereign
Wesley chapel
This is the contact info of where I buy from
The spread rate for Super Therm is 90sq/ft/ga
The spread rate for HSC1000 is 60 sq/ft/ga
Price Super Therm $75.00/ga., HSC1000 $42.00/ga
Dennis Watters
Superior Coatings International
805-200-8814
10-09-2011, 08:10 PM
#252
1972 31' Sovereign
Wesley chapel
Here is a good example video on supertherm. Stuff is pretty amazing.
10-14-2011, 11:49 AM
#253
1972 31' Sovereign
Wesley chapel
10-23-2011, 03:13 PM
#254
Always learning
1972 29' Ambassador
Central
Mirrors
Dark,
Just wondering if you got the 3M window film in yet. I'm looking for the same thing for Abby. Thanks!
Lance
10-23-2011, 06:40 PM
#255
1972 31' Sovereign
Wesley chapel
Originally Posted by Top
Dark,
No not yet but I will report when it arrives..
10-28-2011, 04:20 PM
#256
1972 31' Sovereign
Wesley chapel
---want to thank Smokelessjoe for for documenting his system!
Well today was a crappy rainy day so i decided to work on the hot water / heating layout.
Primary heat : 20kbtu evacuated solar collector
Secondary heat : 17kbtu diesel hydronic heater
emergency heat : 120v resistive element
PLC will decide if there is enough solar heat to meet demand, if not then it will fire the diesel heater. If both fail it will activate the 120 resistive element.
PLC can also switch a cabin heat circuit between heat sources.
10-28-2011, 04:29 PM
#257
Vintage Kin
Fort Worth
Glad there is more interest in this. I'd be more than happy to sacrifice the propane furnace for an (admittedly more complex) diesel-fired hot water & furnace replacement. We already know that sealed ovens/stovetops exist as well, but I either can't remember, or have missed, diesel-powered RV-sized refrigeration. Much as I like some things about propane, I'd rather be rid of a second fuel (with a diesel-powered TV assuming I don't add propane injection to it).
Thanks for posting schematic!! (Both of you responsible).
10-28-2011, 04:41 PM
#258
1972 31' Sovereign
Wesley chapel
No problem.. I dont like propane.
My plan is a
Wallas 87D combined oven & hob
and a
VITRIFRIGO DP2600iXAC 24vdc fridge (65watts)
10-28-2011, 04:48 PM
#259
Vintage Kin
Fort Worth
10-28-2011, 05:06 PM
#260
1972 31' Sovereign
Wesley chapel
Thats the one! You can get the full stainless for about $1200 and its got the DanFoss
