07-17-2011, 09:58 PM
#201
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
Without jacking a corner everything sits perfectly level - as built
I was jacking up a corner as a test.
I did not want the frame to be unable to twist ( super rigid )
For example.. If I had not used two 'L' s as cross members... say I used a 10" ibeam or 10" box section as cross members, the frame would have been much more rigid - maybe too rigid..
07-17-2011, 10:02 PM
#202
Columbus
, Ohio
Ahh! I get it now, thanks!
07-17-2011, 10:11 PM
#203
1972 31' Sovereign
Wesley chapel
There is another little trick.. the outriggers ( 3" tall ) are welded to the side of a 10" tall tube. This may look super rigid but it is not ( by design )
The outrigger if loaded deflects ( deforms ) the side of the tube because where it is imparting the most forces is part of the way down the side of the tube where it can most easily be compressed. If you stand on my outriggers they feel springy
07-19-2011, 01:16 PM
#204
Columbus
, Ohio
How will you put together the axle supports? On my frame there is a 1/4 plate with holes welded to the outside of the frame, then a Z channel bolted through the pate and the C channel. The axles are mounted to all of that. The bolt is fairly short, and does not go through a hollow cavity, such as a rectangular tube. Compressing the tube would be my major concern.
07-19-2011, 04:47 PM
#205
1972 31' Sovereign
Wesley chapel
On page ten of this thread look at the drawing with "side mount hanger" it gets welded to the bottom of 2x10 tube and from there the new axle bots to it.
07-19-2011, 04:50 PM
#206
1972 31' Sovereign
Wesley chapel
O' old axle how I despise thee...
Took the bolts out and it would not come down. Had to beat it down with a sledge. Think the old frame was flexing on it and wedging it in.
07-19-2011, 09:14 PM
#207
1972 31' Sovereign
Wesley chapel
Well it officially sucks to put old rot axles on a new frame. The plan is to finish the AS then weigh it, then order new axles
07-19-2011, 09:22 PM
#208
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Yeah it kinda sucks, but it is just a few extra hours of work. Just wondering what your plan is for attaching the belly pan to your outriggers. I like your maverick style of engineering and fabrication. Since you have an extra 2" of height for the axles, are you going with 0 degree starting angle?
Lance
07-19-2011, 09:32 PM
#209
moderator
2012 25' FB Flying Cloud
Wilton
Thats a good question.. What will the wheel look like in the well visually? 20" wheels lol
07-19-2011, 09:44 PM
#210
1972 31' Sovereign
Wesley chapel
Thanks!
The outriggers are not complete, there is a water jetted piece that attaches to the vertical of each outrigger to form the belly wrap radius.
The belly pan is still in the design stage as there will be an aluminum battery box before and after the axles on each side. So 4' before and after the axles will be compartment that opens from the outside. The rest will be belly wrap and banana wrap
07-19-2011, 09:47 PM
#211
1972 31' Sovereign
Wesley chapel
Super Swampers...
No actually the wheel well arch is going to be lowered to look more - normal - what ever that is..
I have some 66" x 12" aluminum plate fender wells in the works
07-19-2011, 09:52 PM
#212
1972 31' Sovereign
Wesley chapel
Well Im not sure I want to do that as I would end up 'too low 2 tow"..
My plan was to keep the stock ground clearance and just relocate the wheel well / skin to match.
Its actually nice because the wheel well inside the trailer has been reduced by 5" in height
07-19-2011, 09:59 PM
#213
Always learning
1972 29' Ambassador
Central
Ah I see. Yes that would be a little too low. Interesting. So two battery compartments 'eh. 100 gallons of fresh water. I think you may need two 6,500lb axles!
Lance
07-19-2011, 11:56 PM
#214
1972 31' Sovereign
Wesley chapel
Hey just because you can hold 100g does not mean you have to carry 100g  Maybe 5200lb
07-20-2011, 06:00 PM
#215
1972 31' Sovereign
Wesley chapel
Twist test on factory wet noodle...err I mean frame... Lol...
07-20-2011, 10:30 PM
#216
Florissant
, USA
Wow...you are ZOOMING along on this project.
07-21-2011, 03:56 PM
#217
1972 31' Sovereign
Wesley chapel
Well I don't have a girlfriend at the moment so I have some spare , time , energy , and money.... Hope that does not Change before I get a lot more done... But there was this hot girl at subway today... But I digress..
07-21-2011, 04:42 PM
#218
1972 31' Sovereign
Wesley chapel
Today was stormy so I decided to keep my wing grounded...
07-27-2011, 07:29 PM
#219
1972 31' Sovereign
Wesley chapel
I was curious about building a custom sofa....
Ok well the google search started with " build a sofa "
That lead me to " schneider trailer "
That lead me to " Stefanie Schneider - Daisy In Front Of Trailer "
Dam you gooogle....
What was I curious about again???
http://www.instantdreams.net/main - artist Stefanie Schneider
07-27-2011, 08:39 PM
#220
Always learning
1972 29' Ambassador
Central
Something about being on the sofa with Stephanie? I don't know. Thanks for the pic.
Lance
