RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-17-2011, 12:48 AM   #181
Trex's Avatar
1981 20' International
Shasta Lake City , California
Looks like the frame on my old Toy Hauler....
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: https://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 07-17-2011, 06:44 AM   #182
Bauxter's Avatar
Columbus , Ohio
Dark, Were you able to get the steel for the full length of the main-rail, or did you have to use 2 pieces. Most suppliers I queried had a limit of 20 feet. Also, is the main 3/16?
When you get ready to lift that monster, you may want to take your vitamins!! .
Bauxter is offline   Reply With Quote
Old 07-17-2011, 07:16 AM   #183
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Yes A500 3/16" - good steel from Canada!
If they sell 20' material, they can get 40'.
I figured my frame rails, front and rear boxed cross members, and A frame material so it could be cut from two 40' sticks with minimal waste. When I got the first quote they quoted four 20' , and I said no, I required 40'. It only took one extra day and the price was the same.
Darkspeed is offline   Reply With Quote
Old 07-17-2011, 07:18 AM   #184
Bauxter's Avatar
Columbus , Ohio
curved front and outriggers
These are the pieces I mentioned in the PM. The front of the frame, that transverses from one main to the other, has a slight curve to it. I called it a cross-member, and may have been incorrect terminology. The outrigger also has a curve to allow the belly wrap to have a curved appearance. I was curious (mainly) on how you would accomplish the curve on the front piece. I assumed the outrigger could be cut to a curved shape, or the aluminum would have its own shape, and the outrigger shape would not be important.
ID:	135048   Click image for larger version
Old 07-17-2011, 07:20 AM   #185
Darkspeed's Avatar
1972 31' Sovereign
Originally Posted by Airslide
No freaking out here.. That box frame is overkill and a nice addition to the airstream. Have you seen this setup used before or did you just dream it up?
Vinnie
Just dreamed it up staring at bridges... Lol
Thought it was easier than drilling holes for wiring , plumbing, etc...
Old 07-17-2011, 07:31 AM   #186
Darkspeed's Avatar
1972 31' Sovereign
O'ok that's easy..
If you take a length of angle it has two flats that form the L shape. Mark a series of lines on one of the flats about an inch apart. Cut these lines all the way through the flat with a saw or grinder. Now you can bend the L in a curve closing the cuts as you bend. Final step is to weld the now closed cuts solid.
The outrigger curves can be cut with a saw or grinder. You can also have your local waterjet / laser shop do them for you.
Old 07-17-2011, 11:30 AM   #187
Darkspeed's Avatar
1972 31' Sovereign
And she has the upper outriggers
Old 07-17-2011, 02:41 PM   #188
Darkspeed's Avatar
1972 31' Sovereign
More
Old 07-17-2011, 03:27 PM   #189
Darkspeed's Avatar
1972 31' Sovereign
Seam welding blows
ID:	135091   Click image for larger version
Old 07-17-2011, 03:33 PM   #190
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
A 10" frame, that's impressive.
That will last another 40 years.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-17-2011, 03:56 PM   #191
Darkspeed's Avatar
1972 31' Sovereign
Thanks, allows for bigger tanks and other storage options.
Old 07-17-2011, 04:20 PM   #192
Darkspeed's Avatar
1972 31' Sovereign
It's a little longer... The A frame starts outside the front cabin. This allows for a small area for a storage box over the A frame
Old 07-17-2011, 05:40 PM   #193
moderator
Airslide's Avatar
2012 25' FB Flying Cloud
Wilton , California
Images: 50
With a 10" frame will you be able to adapt standard sway/ load control and have the correct ball clearance for your tow vehicle?
I know with my airstream the coupler is mounted up high so this lowers the frame and occasionally I drag my bars on uneven surfaces.
This is a picture from another thread but illustrates what im talking about.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-17-2011, 06:07 PM   #194
Darkspeed's Avatar
1972 31' Sovereign
The connector that is on there is temporary. I am considering an adjustable connector. I actually started a thread about it but it seems no one has used on on an AS.
Old 07-17-2011, 06:12 PM   #195
Darkspeed's Avatar
1972 31' Sovereign
http://www.airforums.com/forums/f464...ame-79575.html
Old 07-17-2011, 06:24 PM   #196
moderator
Airslide's Avatar
Wilton , California
Images: 50
Sorry I missed that one. Great topic. It looks beefy but dont know enough about the application of that coupler. If you would like me to combine these two threads I could.
Thanks Vinnie
Old 07-17-2011, 06:51 PM   #197
Darkspeed's Avatar
1972 31' Sovereign
O that's ok.. Someone may see in in the hitch area
Did a twist test as I did not want to be too rigid in twist. From what I understand AS are designed to twist but not bow. Should be ok, the boxed ladder allows for twist but not much bow
Old 07-17-2011, 06:54 PM   #198
Darkspeed's Avatar
1972 31' Sovereign
I like it 2.1 Deg front to back
Old 07-17-2011, 09:54 PM   #199
Bauxter's Avatar
Columbus , Ohio
Dark, Can you expand on the 2.1, I am not following very well. Are you saying that the bubble level is 2.1 degrees from being level?
Looks like a hand gizmo.
Mike
Old 07-17-2011, 09:56 PM   #200
Darkspeed's Avatar
1972 31' Sovereign
The 2.1 Deg is how much twist I could get ( using the jack on one side ) without picking up an opposing corner
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 06:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 09:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 11:38 PM
Replacing Steel Wheels with Aluminum Daystreamin Wheels, Hubs & Bearings 8 02-03-2011 12:27 PM
