RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-28-2011, 08:34 AM   #61
BW
1973 31' Sovereign
Baton Rouge , Louisiana
Send a message via Skype™ to BWMorgan225
Tank Dump Valve Froze
The dump valve will only move approx 1/2" back and forth but will not open. I assume the rust inside is keeping it from opening. Any suggestions? I assume I will have to saw the conduit and replace if I cant get to work.
BWMorgan225 is offline   Reply With Quote
Old 12-04-2011, 01:23 PM   #62
BW
1973 31' Sovereign
I am removing the refrig, stove/oven, pump, electrical converter/panel and furnace from kitchen. If anyone needs any of these contact me. I can send photos.
Bw
Old 04-22-2012, 10:34 PM   #63
BW
1973 31' Sovereign
Been away for a while...my partial renov has become a complete renov of 73. Progress report. photos to follow.
Old 04-23-2012, 10:51 AM   #64
Central , Mississippi
Uggg...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 08-10-2012, 07:17 AM   #65
BW
1973 31' Sovereign
Laminate flooring question...what is the best laminate flooring for AS? Floating, glue or nail down? What thickness is best? Any problems with
floor? etc etc.
thanks
BW
Old 08-10-2012, 11:03 AM   #66
Taylormade's Avatar
1978 31' Sovereign
BW I went with a lightweight floating laminate in my Sovereign. I wanted something lightweight as the trailer and the cabinetry I made for it is plenty heavy. We're casual users of ours, just camping approximately 6 times a year or so.
With any type of laminate you have to be careful of water spills and it's important to have your leaks fixed before installing any flooring. Don't ask me how I know that.
Anyway, we went to a local flooring warehouse and between the peel and stick vinyl for the bathroom and the laminate in the rest of the trailer, it was only around $175.
Your mileage will most certainly vary depending on what you're looking for. I went with the cheap underlayment because we're camping and it doesn't need to be quiet. If we were full timing it, I'd have sprung for the thicker underlayment as well as thicker lam.
Good luck!!
Taylormade is offline   Reply With Quote
Old 08-10-2012, 08:48 PM   #67
BW,
I've done 2 with Allure planks from Home depot, both worked out well. I did a RV with glue down and it lasted as long as I owned it. Peel and stick hasn't worked so good in the one I did...My latest is a Cherry composite from Lumber liquidators. So far...So good.
Old 08-11-2012, 08:56 AM   #68
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did peal and stick in an SOB trailer we owned, and over winters, it would "unstick" in a few spots. When it was warm again, it would stick back down. Replaced a vinyl in one trailer also, and it worked well - just glued at the edges.
We have floating cork in our AS but without use, per se, I hesitate to comment on it's wearability. Looks nice! Didn't shift over last winter (not much of a winter for Minnesota, though).
Kay
Old 08-11-2012, 09:41 AM   #69
BW
1973 31' Sovereign
Good ...I have been visiting Lumber Liquidators here in Baton Rouge. They suggest not using a thin laminate. Make sure its thick enough for the connection between the boards to be secure.
thanks
bw
Old 08-11-2012, 08:39 PM   #70
thanks
bw
The Cherry laminate I'm using is 1/2" thick and snaps together. It's hard as a rock, I killed a bandsaw blade doing the trimming. Sparks would fly when I cut it.
Old 08-13-2012, 05:41 PM   #71
Minno's Avatar
1972 31' Sovereign
I wonder if that's the laminate that has metal (aluminum oxide?) finish on it... Supposed to wear really well.
Kay
Old 08-19-2012, 02:30 PM   #72
BW
1973 31' Sovereign
Anyone replaced an AC thermostat with a new digital? My old one is a Honeywell. Any suggestions on a new one? Model?
Old 03-14-2013, 10:09 AM   #73
BW
1973 31' Sovereign
Need help on awning for '73...I have some hardware but missing pieces. When I purchased AS just the support (long pieces) was in place. None of the hardware for opening and locking awning was inplace. Can someone share photo of awning hardware and how it locks the awning open? bw
Old 11-22-2013, 12:36 PM   #74
BW
1973 31' Sovereign
Grey water rule
anyone familiar with rule for grey water discharge from sink/shower (non-septic) in state and fed parks? especially in NC, KY and VA parks. do they allow ground discharge?
Old 11-27-2013, 01:07 PM   #75
I haven't seen an established park in YEARS that would allow any discharge.
Old 01-26-2014, 12:53 PM   #76
BW
1973 31' Sovereign
Anyone from Kentucky or NC? I have info on NC state parks but looking for other RV opportunities in both states. Will be traveling siteseeing and doing some genealogy work in KY and NC. Areas that I will be mostly visiting are Winchester/Boonesborough KY and Asheville NC. Any familiar with these areas?
Old 04-15-2014, 06:55 AM   #77
BW
1973 31' Sovereign
I would like to replace my old Honeywell thermostat for my roof AC. Does anyone know of a digital nonprogrammable cooling only thermostat that would work on this unit?
1973 sovereign, mid bath, sovereign
1973 26' Argosy Restoration bbnaugher All Argosy Trailers 14 10-09-2011 08:35 PM
1973 avion le grande 31' like airstream eBay Watch Airstreams on eBay 0 01-22-2011 09:10 PM
Airstream 31' 1974 sovereign eBay Watch Airstreams on eBay 0 01-10-2011 04:20 PM
International Sovereign Airstream Ready to Use 31 foot eBay Watch Airstreams on eBay 0 01-06-2011 08:00 PM
