This Wiki page might help... I would go to the trailer with a voltmeter, some jumper wires, a new cable that fits the truck, with modern connector and wiring/color conventions, and then test and wire each connection on the trailer individually. First determine which pin on the trailer is ground, using the ohm function of the voltmeter; then connect the negative of a test power source (a spare
12V battery) to the ground pin and use a 20A fused wire to test each remaining circuit and wire the connector accordingly. Finally, test it with your truck, before going anywhere.
