Old 10-01-2017, 07:39 AM   #1
1973 31' Sovereign
university city , Missouri
New here, help with pricing? 1973
Hey guys, im new here and was wondering if i could get some help pricing my 1973 airsteam sovereign, was my fathers but i inherited it a few years back, it does need a little TLC but its all orginal interior,
ID:	295944   Click image for larger version
ID:	295946   Click image for larger version
McGoogs is offline   Reply With Quote
Old 10-01-2017, 08:42 AM   #2
1981 31' Excella II
New Market , Alabama
Probably in the $5k-$10k range depending on what it needs. Most require a complete overall and fixing of rear end separation. Also new appliances and some folks will add a gray water tank since these old models don't have them. The interior is not all that desirable in that era since most of the wood was replaced with plastic or plastic coated wood. Biggest issue with the old ones is rear end rot which causes structural problems especially in the rear bath models.
Perry
Old 10-01-2017, 09:12 AM   #3
1973 31' Sovereign
there is one small board in the back with a little rot, was planning on changing that out. mostly cosmetic damage, electrical works, appliances work, good plumbing.
Old 10-01-2017, 09:21 AM   #4
1981 31' Excella II
Replacing the floor is not usually that simple. Spend some time in the floor ans frame repair forum on here.
Old 10-01-2017, 09:35 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The 73 I bought looks to have been in roughly the same condition, I paid 5K for it, and then bought a similar 75 for 3K.
The 73 needed the bath floor replaced and a few patches forward around the windows. It had rear separation, which required a few days work to fix , The 75 was made serviceable with a few patches up front.
Old 10-01-2017, 02:18 PM   #6
Trnpk Crsr's Avatar
Baltimore , Maryland
I think that your AS is newer than 1973. A center bath was not available in 1973. Does your AS have a grey water tank? If it does, it is newer than 1973. Also, 1973 AS had wall ovens. Your AS does not.
Cheers,
John
Trnpk Crsr is offline   Reply With Quote
Old 10-01-2017, 06:26 PM   #7
1973 31' Sovereign
the title says 1973 and i found a floor plan in the owners manual for it aswell, cant remeber the exact model,
Old 10-01-2017, 07:12 PM   #8
1981 31' Excella II
I did not catch that is was a center bath. That makes it easier to fix.
Perry
Old 10-01-2017, 09:39 PM   #9
Trnpk Crsr's Avatar
I went back and looked. There were two center bath models in 1973. There was a 29 ft. Amassador and a 31 ft. Sovereign. I didn't remember them.
John
Old 10-02-2017, 10:43 AM   #10
kdickinson's Avatar
Taos , New Mexico
I inherited a 1969 from my family about 3 years ago - it is great that we are fortunate to have it now. Lots of good memories tied to that Airstream from the 70's! If you don't go through it and replace worn / non-working components I would expect that a potential buyer will want to factor repair / replacement cost into a purchase price. I have no idea what ours would sell for now because there are so many variable factors involved - best bet is to keep an eye on the RV Trader site and the AS Forum marketplace to get an idea for what similar units are listed for without a good way to find out what they actually sold for. In the end it's probably get some good pictures, list it for around what you would like to get and work through the process - it's worth what someone will pay for it.
kdickinson is offline   Reply With Quote
Old 10-02-2017, 10:58 AM   #11
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I agree with Perry, but think that he's a bit high. The little Airstreams sell for lots more than the big ones. I also agree that the original interior is more of a detriment than a bonus- most folks just want to rip them out and start over.
The center bath is good, though. It means that you probably don't have the dreaded rear bath floor rot, and subsequent floor/frame separation.
Difficult to tell from the pic, but it looks like it needs new axles- most trailers of this vintage do.
These days it's difficult getting an idea of pricing on Craigslist, between all of the scams and price typos. If you have lots of time, you can try to sell for a higher price. You'll get lots of tire kickers that think they're getting a $25K+ trailer for cheap, and then be disappointed at the 70's interior.
SuzyHomemakr is offline   Reply With Quote
Old 10-02-2017, 12:03 PM   #12
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
There may be more floor rot than you see. When an Airstream leaks the water often runs down between the outer and inner skins and then soaks through the holes in the C-channel at the bottom of the wall into the floor. The floor is part of the structure that joins the wall to the frame, so even if the outer couple of inches are rotten it should be fixed. If the floor has rotted there may well be rust on the frame as well. On our '74 Sovereign we had to replace or repair about 3/4 of the outriggers and a few cross members, as well as the floor. There were places where the floor looked okay from above, but the outriggers were rusted out below it.
I'm not suggesting you should get into fixing all this before selling as you're unlikely to get your time and money back, but it's good to know what an educated buyer will be looking at. I wouldn't even bother patching the floor.
As mentioned above, the axles and tires will need to be replaced as well. Trailer tires should be replaced every 5-7 years even if they look okay. Again, I wouldn't suggest that you replace the tires and axles before selling. The buyers may have ideas as to what they want, for example upgrading axle capacity or tire size.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 10-02-2017, 12:07 PM   #13
Reads a lot
Titusville , Florida
You might want to find a Airstream inspector in your area to come out and look at it. He/She would know how much work really needs to b done on it and what a real world price you could start at. Although pictures are nice, boots on the ground is usually better.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 10-02-2017, 02:55 PM   #14
1981 31' Excella II
I expect there is floor rot in the back corners like there are on 99% of east coast trailers. It does not require a total gut to fix it though. My 81 still has most of the original interior. It was on the brink. There is stuff that I would prefer was real wood.
Perry
Old 10-03-2017, 05:44 PM   #15
1973 31' Sovereign
Thank you all for the help!!
It is here! Well, almost here... 1973 Ambassador Pschoerrn 1970 -1973 Ambassador 10 05-20-2005 02:56 PM
Help pricing Argosy to sell LakeCityBoop All Argosy Trailers 2 02-14-2005 07:52 AM
Help pricing 1990 25' Excella nukesul 1990 - 1993 Excella 21 02-14-2005 03:53 AM
Help Pricing 2004 Airstream rcaldwel Trailer Values 3 10-13-2004 11:14 AM
Pricing HELP gandttimes 2005 and newer - Bambi all models 6 09-28-2004 09:00 PM
