Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 - 1973 Sovereign
Old 10-12-2011, 04:02 PM   #1
1970 31' Sovereign
cumberland , Maryland
Need refrigerator dimensions
Hi
I just purchased a 1970 airstream international sovereign without refrigerator . could anyone please tell me the refridgerator dimension requirements for this trailer. non in it when purchased but has a dometic manual that says refrigerator for trailer installation m70b, thanks jack
travalota is offline   Reply With Quote
Old 10-12-2011, 05:01 PM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Find dimensions for modern Dometic refrigerators at their site.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-12-2011, 05:29 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
need refrigerator dimensions
Greetings travalota!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by travalota View Post
Hi
Dometic was the RV refrigerator of choice when our Vintage Airstreams were manufactured. Today, Dometic offers a variety of options in their new refrigerators, but you will likely find that any of the new refrigerators will be either slightly smaller or slightly larger than your coach's original. Some cabinet modification will almost certainly be required. You can find the Dimensions of the current Dometic offerings at this link.
You will also find that you have the option of LP Gas/120-volt AC fueled boxes as well as LP Gas/120-volt AC/12-Volt DC fueled boxes. Only the first option was available when your 1972 was new, but it does not mean that the second choice could not be retrofitted as I had this done in my '64 Overlander. The 3-way refrigerator (LP Gas/120-volt AC/12-Volt DC) gives the option of traveling with the LP valves in the off position . . . something that is a very important safety consideration for me (be forewarned that opinions vary greatly on this issue). My first new RV (a 1980 Nomad 1720 travel trailer) had a 3-way refrigerator, and I have traveled happily and confidently ever since with 3-way refrigerators (the 12-volt DC maintains cool but does not work for cooling a warm refrigerator). My Minuet will receive a 3-way RV refrigerator when its original Dometic ceases operation.
Good luck with your research and investigation!
Kevin
P.S.: Norcold also offers a number of possibilities including 12-volt-DC compressor type RV refrigerators . . . see this link.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 10-12-2011, 05:54 PM   #4
1970 31' Sovereign
Thanks for replys. The problem is I found one ( a 2 way)on craigslist that i need to snap up if i want and my trailer is somewheere else and I cant get there to measure the space so i was hoping someone would just know the standard size that went in the 70 31 ft international sovereign. i understand it was 7 cu ft dometic
Old 10-12-2011, 06:15 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There is no standard size. This chart will give you all the dimensions for Dometic units.
http://www.dometic.com/c17faeab-a5a2...17a7cff0.fodoc
Richard
Old 10-12-2011, 07:50 PM   #6
1970 31' Sovereign
thanks but my concern is not what size refrigerators come in. My question is what is the maximum size refrigerator that will fit in a sovereign international 31 ft trailer cabinet space because i dont have the trailer here to measure it...sorry for confusion
