10-04-2012, 12:58 AM
#461
Bothell
Very nice Kay!
10-04-2012, 07:10 AM
#462
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck
, North Dakota
Beautiful all the way around
Originally Posted by Minno
Waaay back in post 45 on 10/1/09, I posted a picture of a quilt top I had designated for the Airstream, to complete when we were ready to start using the trailer. WELL, here it is! All quilted and finished and "installed" on the bed. It is SO nice to be able to put things in the trailer that we have planned and dreamed about for what seems like soooo long!
Kay
Love the quilt and the work that has been done on your trailer. It is fun to see the progress as it goes along and thanks for sharing the pictures. It all looks great.
Sandy
10-05-2012, 06:07 AM
#463
1971 29' Ambassador
guyton
, Georgia
wow looks great live in ga now from braham mn.years ago.
10-05-2012, 01:49 PM
#464
Ottawa
, ON
Suh-weet, Kay!
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
01-28-2013, 06:04 PM
#465
1972 31' Sovereign
Lexington
Finally, she's bubbled back to the top of the list! That happened about 2 weeks ago, and then the highs here were below zero. I was going to start working on the front shelf over the window, but was afraid I would somehow crack the front headliner, so I abandoned that idea and switched to something that I can build mostly in my workshop - the base cabinet for the microwave. Have I mentioned my worshop is heated?
Here's what I have cobbled together so far.
I have the face frame together and mounted to the two side panels. This cabinet will install directly to the left (aft) of the fridge. The converter will mount in the lower right-hand opening, with a small door to the left of it. Then two 6 1/4" deep drawers, and finally a pull out cutting board. I used ½” plywood for the sides and our standard wood (red alder) for the face frame. The left side is partially skinned with red alder plywood, as that part will be exposed.
Next to this cabinet on the left, and all along the wall heading aft to the bathroom will be 13 inch deep cabinets containing drawers and closet space. Those plans are still milling around in our heads, but the wardrobes will probably not be big enough to walk into and find the lion or the witch...
Chris
01-28-2013, 08:00 PM
#466
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
What a fantastic job! I just caught up on your thread. She looks wonderful, and has to be so personally satisfying to be out camping in her.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
01-29-2013, 06:42 AM
#467
Columbus
, Ohio
Inquiring minds want to know
Pocket screws?
Looking real nice!
Way nicer than my trailer plan, Ikea cabinets wedged in with a crow bar and a glue stick
01-29-2013, 07:40 AM
#468
1972 31' Sovereign
Lexington
Thanks Aviator!
Bauxter; yes, pocket screws hold the face frame together and the sides to the face frame. I can get a picture of the back of the face frame if you want to see the joinery.
Chris
01-29-2013, 01:22 PM
#469
Columbus
, Ohio
Of Course! And don't forget your flashlight, I seem to remember some dark pictures...
01-29-2013, 04:51 PM
#470
1972 31' Sovereign
Lexington
You're in luck - it was still daylight when I took these!
Inside of the cabinet showing the pocket screws that hold the face frame together and one of the sides onto the face frame. The extra pieces of basswood nailed onto the back of the face frame serve two purposes. One is they position the sides in the correct place while I installed the pocket screws, and two, they will provide a mounting point for the drawer slides.
Here’s the other cabinet side with the pocket screws on the outside of the cabinet. Did them on the outside this time because this side of the cabinet will be against the fridge cabinet and will not show, plus it lets the screws go into more meat of the face frame so help ensure it disn't split.
Close-up of the joinery.
I love pocket screws. They are quick, easy to use, and strong. Plus, once the screws are installed, no clamps are needed. I use 3 different sizes. 1 1/4" for most 3/4" thick face frame joints, 1 1/2" for anything thicker than 3/4" thick, and 1" for attaching the 1/2" plywood to the face frames. For this soft red alder, I'm using the coarse thread pocket screws. For oak or maple, I would use fine thread.
Chris
01-29-2013, 05:30 PM
#471
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
wow.....amazing craftsmanship....again...wow...
Still One Nation under GOD
2 chronicles 7:14
01-29-2013, 07:24 PM
#472
Central
, Mississippi
That is some really nice woodwork. It looks like it will hold, what, 16 wine bottles? ;0)
01-29-2013, 09:40 PM
#473
1972 31' Sovereign
Lexington
Lets see: 4 inch diameter holes, 21 inches apart... how big a wine bottle can we put in there? What color wine?
Kay
01-29-2013, 09:48 PM
#474
Central
, Mississippi
Kay
Square them up and it will hold a full case of box wine! Gee, that's at least 4 gallons and will cost more than $20 - $30 bucks!
Seriously good looking woodwork. What kind of wood is that?
01-29-2013, 09:59 PM
#475
1972 31' Sovereign
Lexington
The face frame is red alder - varnishes to look like new cherry, but won't darken over time and is half the weight of cherry. Boards are a decent price, plywood veneer is not cheap. He used regular half inch plywood on the hidden areas. He uses basswood for hidden framing too, due to weight.
Heck, I was thinking Boones Farm. You know, revisit our youth, etc. Does it come in boxes now?
Kay
02-02-2013, 09:24 PM
#476
1972 31' Sovereign
Lexington
Drawer Box Construction
02-18-2013, 09:57 AM
#477
1972 31' Sovereign
Lexington
Finally had time to get 3 coats of poly on the microwave cabinet, drawer boxes, drawer fronts, and the door.
Like the other cabinets, I installed aluminum strips on the back edges of the plywood to attach the cabinet to the wall. I used 1 1/4" long #6 screws and red lock-tite to hold the screws in. Note: the cabinet is sitting upside-down on my table saw in these pictures in case that threw you off.
Here it is sitting in place. We'll wait for the weather to warm up a bit before doing the installation. I need to move the outlet up a bit to clear the countertop, and pull the converter out of the plywood box we stuck it in last year.
I have today off, so I'm going to start working on the table that goes over the battery box in between the two recliners at the front of the trailer.
Chris
02-24-2013, 04:32 PM
#478
1972 31' Sovereign
Lexington
02-24-2013, 06:20 PM
#479
Central
, Mississippi
Your woodworking skills are amazing.
02-25-2013, 07:36 AM
#480
1972 31' Sovereign
Lexington
Thank-you.
