RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-27-2011, 07:11 PM   #201
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Built the bottom of the second gray tank yesterday and today. Measured the inside dimensions, and the capacities of the tanks will be 24 1/4 Gals and 20 1/2 Gals, giving us a total gray water capacity of 44 3/4 Gals. Plus a couple of gallons in the drain pipe between the tanks and the dump valve. Not bad at all. Certainly worth the work involved.
Old 03-05-2011, 12:07 PM   #202
1972 31' Sovereign
whitethorn , California
i just bought property with an abandond airstream 1972 sovereign. in fair shape i love the little porthole windows. im a rookie airstreamer and already excited about the possibility's. any info -advise and links for restoration and just knowledge about this would be appreciated. are these rare? thx donovan
donovan is offline   Reply With Quote
Old 03-05-2011, 12:21 PM   #203
Minno's Avatar
1972 31' Sovereign
Geez, you're lucky! There's lots of threads that can take you through reno or restoration depending on what you want to do with her. I don't know about rarity - I think Sovereigns are not all that rare. Older trailers in the 30's, 40's and 50's are more highly prized from what I've read. We wanted the length, and like the lines of the early '70's AS's. Our's had a very rotted floor, damaged frame in some areas, and had been partly taken apart on the inside when we bought it, which is what we were looking for. Our plan is to keep the outside as vintage as we can, but have an all new interior designed for our tastes. Check the floor carefully, especially in the rear where there's a known flaw in design that lets water in to the floor. There's also the very common "rear end separation" especially in rear bathroom AS's. It's all fixable! Just takes time and money... There's lots of very good information on these forums, so do some reading!
And welcome!
Kay
Old 03-05-2011, 08:26 PM   #204
Minno's Avatar
1972 31' Sovereign
Did some more work on the two gray tanks today. Cut 4 inch long pieces of 1/8” thick ABS to form reinforcements for the corners. I want to make sure the corners will not burst out if we ever travel with the gray tanks full.
Name:	0305 corners 01.JPG
ID:	123746Click image for larger version
Name:	0305 corners 02.JPG
Heated them on the center line, and then bent them in place on each corner of the tank to ensure a good fit. Managed to not burn myself at all doing this.
Name:	0305 corners 03.JPG
ID:	123748Click image for larger version
Name:	0305 corners 04.JPG
Once I had all four reinforcements made, I glued them using the 4707 ABS glue I bought, and clamped in place for a couple of hours.
Name:	0305 corners 05.JPG
Removed the clamps, and will let sit overnight as the glue directions say full strength will occur after 24 hours.
Now, inside on the computer posting this, and then on to the layout of the black tank. That’ll be more interesting as I do want the bottom to slope towards the drain outlet.
Chris
Old 03-06-2011, 10:14 AM   #205
1973 31' Excella 500
Spring Green , Wisconsin
Chris, you are having way too much fun with that bending apparatus! Seriously though, these are some really interesting things you are doing with the ABS.
Have you thought of making new wheel wells, or wouldn't the ABS be suitable for that? I've seen quite a few posts where folks spend a lot of time repairing their wheel wells. Just wondering if you think this would be an option.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 03-06-2011, 02:08 PM   #206
Minno's Avatar
1972 31' Sovereign
I think the ABS sheet would be great for making new wheel wells. I repaired the black inner ones already, and they were a lot less than 1/8" thick. I'm not going to rip them out and build new ones though. But, I may make new ones to replace the cream colored ones that mount over the black wheel wells. I need to look at them again next summer and see just how bad they are.
Old 03-06-2011, 04:50 PM   #207
Central , Mississippi
That ABS is fun to work with. I used a similar technique to build a shower pan...years ago...black silicone worked GREAT as a seal in my application...of course I wasn't drinkin from it either
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-06-2011, 05:56 PM   #208
Minno's Avatar
1972 31' Sovereign
These are gray and black water tanks.... I really don't plan on drinking from them either! Plus, the ABS sheets I'm using are not rated for potable water.
Old 03-06-2011, 06:32 PM   #209
Minno's Avatar
1972 31' Sovereign
Today, I cut out and bent the bottom of the black water tank. The biggest challenge I ran into was how to build the tank with a sloped bottom without requiring all the seams be welded together. Not that I object to welding, but bending is faster and a heck of a lot less stinky!
Name:	Black Tank 01.JPG
ID:	123824Click image for larger version
Name:	Black Tank 02.JPG
Here, I have the bottom cut out, and I’m heating the place on the bottom that will end up being the low spot on the tank. Both sides will slope down to this low spot, and the outlet will be attached to one side at this spot. In the second picture, you can see where I made a relief cut on the side at the bending point. This is needed so that once the tank bottom is bent, I can bend the sides up to form them. I ended up cutting a wedge shaped piece, just under a ½” at the top, so the two pieces of the side would bend up next to each other.
Name:	Black Tank 03.JPG
ID:	123826 Click image for larger version
Name:	Black Tank 04.JPG
Here, on my workbench, are two supports. The close one is ¾” high, and the far one is 1 ½” high. In the second picture, I have the now heated bottom of the tank resting on the workbench and supports to form the bend in the bottom.
Name:	Black Tank 08.JPG
I left the bottom on the supports to bend the sides, and used a square to make sure that the ends where 90 degrees to the bench top, and not 90 degrees to the now sloped bottom.
Name:	Black Tank 09.JPG
ID:	123829Click image for larger version
Name:	Black Tank 10.JPG
Here’s two pictures of the tank bottom with the ends bent, and the longer sides bent. This is when I measured to see how much of the short piece I needed to cut off so it would clear the long side piece once I bent it up to 90 degrees.
Name:	Black Tank 14.JPG
ID:	123831 Click image for larger version
Name:	Black Tank 15.JPG
Here’s the bottom of the tank formed. All the seams still need to be welded, and the extra cut off the sides. In the first picture, you can see how the tank is sloped, and in the second picture, you can see how the two side pieces came together. I’m going to reinforce that seam on the inside with a piece of 1/8” ABS as well as weld it together.
Name:	Black Tank 17.JPG
The blue masking tape (which came out quiet bright in the flash!) shows the extra I need to cut off the sides in order to attach the top and end up with a flat top. The bottom of the tape is my cut line.
The tank is 5 ¼” deep at the low point, and slopes up to 4 ¾” on the short side, and 3 ¾” on the long side. Same basic height dimensions as the original black tank that this will replace. It’s a tad larger in both length and width, as I’m not going to try and provide heat into the black tank box like they did originally.
But the main reason for building a new black tank is so we can relocate the toilet and have the tank drain towards the front of the trailer instead of towards the rear bumper.
Old 04-21-2011, 04:33 PM   #210
Minno's Avatar
1972 31' Sovereign
It's been awhile since I've had time to work on Little Girl. But, last weekend I had some free time to work on her, and I did the final construction of the bottom of the black tank.
Name:	0421 blk 01.JPG
I welded the 4 corners as well as the seam where the tank makes it bend at the bottom. I also cut the top of the tank off to make it level once it’s installed. I need to file the corner reinforcements down a bit, but other than that, the bottom is ready for a trial fit under the floor.
Name:	0421 blk 02.JPG
Here’s a close up shot of the side seam. It’s welded, and then covered with my slurry mixture of ABS and MEK. I used this same slurry on all the inside seams as well.
Name:	0421 blk 03.JPG
Close up of one of the corners and the reinforcement I glued on.
Name:	0421 blk 04.JPG
ID:	127811Click image for larger version
Name:	0421 blk 05.JPG
These 2 pics show the 1/8” thick reinforcement I added to the inside of the side seam. Kinda hard to see, but the reinforcement piece is about 16 inches long total.
We also bought a few more items in preparation for working on the bathroom this summer:
Fittings for the ABS tanks
Water heater (6 gal gas with electronic ignition)
ABS pipe for the drains & tank vents
PEX for fresh water (blue & red)
PEX clamps and a crimping tool
We’re both getting Spring Fever really bad now! Can’t wait to get out there and actually work on her again!
Chris
Old 04-24-2011, 12:58 PM   #211
Minno's Avatar
1972 31' Sovereign
Name:	0423 bath layout 01.JPG
We spent some time yesterday playing with the layout of the bathroom. This is what we came up with for the fixtures. The blue tape on the floor is the wall and door opening between the bedroom and the bath. We’ll build a vanity to house the sink (as well as other cabinets), and installing it there next to the tub not only works for us, but it will make plumbing sooooo much easier.
One of our concerns with the tub was making sure I’ll have enough head room while taking a shower. And even with it most of the way against the outside wall like it is, I will.
It’s nice out today, so maybe I can play with trial fitting the tanks under her this afternoon.
Chris
Old 04-24-2011, 01:35 PM   #212
Trex's Avatar
1981 20' International
Shasta Lake City , California
Originally Posted by Minno View Post
Attachment 128007
Chris
Nice layout.... Looks like you made "The Turn" and now the fun begins.
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: https://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 04-24-2011, 03:55 PM   #213
Minno's Avatar
1972 31' Sovereign
We did a trial fitting of the tanks this afternoon. Word to the wise - do not build tanks in the winter when you can't get out and crawl under the trailer to double check dimensions...
Although actually, the gray tanks will fit ok once I cut the flanges down a bit. That's something I was half expecting to have to do anyway, so maybe it's not so bad after all.
A kinda funny happened with the black tank. I measured and built it so it would fit inside the metal box that holds it to the bottom of the trailer. Then I had this wonderful idea that I should reinforce the corners of the tank like I did the gray tanks. The reinforcements made the tank too big to fit inside the metal box! Oppsy!
Oh well. We pondered a few things we learned doing the trial fittings, and we have a plan for going forward. Like grinding off the reinforcements for starters. I'll post pictures of any real progress we make, but that'll probably be a couple of weeks from now.
Old 04-24-2011, 10:18 PM   #214
Trex's Avatar
Sorry to see you're having set backs...one step forward, three steps back.
Old 04-25-2011, 08:07 AM   #215
Minno's Avatar
1972 31' Sovereign
At least it's all self-induced set backs, so fairly easy to overcome.
Old 05-14-2011, 09:18 PM   #216
Minno's Avatar
1972 31' Sovereign
Finally, we were able to spend time working on Little Girl again today! Started out with a supply run to Youngblood to pick up some red alder and basswood. We’ll use basswood for the cabinet frames since its nice and light, and red alder for the interior wood.
It was rainy pretty much all day, so we did inside things once we got back home. The first project was to install the front headliner we bought. It’s actually a rear bath headliner for a ‘70’s Airstream, but I figured it would fit in the front just fine.
Name:	0514 headliner 01.JPG
Step 1 – insulate. Actually, that was step 2. Step 1 was adding a 12 volt power wire and ground to the front for the stereo, something I forgot to do when I did all the rough wiring last year. Good thing I caught it before installing the headliner!
Name:	0514 headliner 02.JPG
Here’s the headliner, and the 2x3s we used to prop it up in place. It was quite a bit lighter than the rear headliner in Little Girl, so the two of us could get it in place pretty easily. Propped it in place with the 2x3’s and marked where we needed to cut it off to fit.
Name:	0514 headliner 03.JPG
That threw us off for a bit, because if you look at the blue tape cut line, it’s not straight across the headliner. After much careful measuring, we confidently determined that the headline itself was not square. One side was about 4” longer (wider?) than the other side. Cutting it off was easy – used a dremel motor tool and cut off wheel.
Name:	0514 headliner 04.JPG
Then we put it in place, and have it held up with clecos right now. I still need to fix the vista view blinds and install them before we can rivet everything in place.
Name:	0514 bath headliner patches 01.JPG
ID:	129840Click image for larger version
Name:	0514 bath headliner patches 02.JPG
Then we spent a bit of time filling holes in the rear headliner. Actually, Kay did that while I cut more holes in the headliner for the bathroom outlets on either side of the window. We used the ABS slurry I made for building the black and gray tanks to fill the holes. Plus a bit of fiberglass mesh tape for the 3 large holes (the big black spots). We’ll let that set up over night, and then sand the headliner tomorrow in prep for painting.
Name:	0514 bath outlets 01.JPG
ID:	129842 Click image for larger version
Name:	0514 bath outlets 02.JPG
Name:	0514 light wires starboard 02.JPG
ID:	129844Click image for larger version
Name:	0514 outlet behind fridge 01.JPG
The last thing I worked on was installing the rest of the 110 VAC outlet boxes. Two in the bath, one in the front starboard corner, and one on the port side just in front of where the fridge will be. This place had one of the original outlet boxes before, but those all were used in other locations, so I had to make a patch to cover the hole and install the smaller new outlet box into the patch. This will be covered with wood paneling, so the patch will be hidden by the time I’m done.
Tomorrow promises to be sunny and nice, so we’ll probably spend time getting our Star stream ready for the 4CU rally in June. Repack the wheel bearings and setting up the hitch to use with our new truck are the two big projects on tap. We are really looking forward to going to that - it'll be our first AS rally!!!!
Chris
Old 05-17-2011, 08:19 PM   #217
Minno's Avatar
1972 31' Sovereign
We started painting this evening! Primed the rear half of the interior. She looks a heck of a lot better now that her walls are all one shade of white! We used Bondz primer and rolled it on.
Name:	0517 rear primed 01.JPG
ID:	130059   Click image for larger version
Name:	0517 rear primed 02.JPG
Old 05-17-2011, 08:28 PM   #218
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Looks great! Really brightens her up.
Lance
Lance M is offline   Reply With Quote
Old 05-19-2011, 05:36 PM   #219
Minno's Avatar
1972 31' Sovereign
First coat of paint.
Name:	0519 1st coat.JPG
Old 05-19-2011, 05:48 PM   #220
Minno's Avatar
1972 31' Sovereign
It's "Pursuit of Happiness" blue.
Kay
1972 sovereign
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 8 09-13-2012 04:43 PM
New member, looking to get 22' refurb daninsatx Member Introductions 1 10-23-2006 10:09 PM
Interior refurb on Argosy RV abridges01 Classic Motorhomes 5 09-02-2006 03:24 PM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-17-2005 12:31 AM
