Originally Posted by ron.seymour
hey here the question!!! I wondering if its going to be too much weight for it? or do I need to put a reguar bed back there instead. the othere question is It got reguar car tire on it 215 75r15 on what do I need to put on so I do have to worry about it going down the road. load range and size. thank ron at edmond,oklahoma.
Ron, the waterbed is waaay too much weight. Many homes and apartments will not stand a waterbed, at least on the second floor. Not only do you have almost a thousand pounds of water, you also have several hundred pounds of particle board, and steel framing. Even if (and it's a big if) the frame of the trailer will stand the weight, you will almost certainly have a negative tongue weight, which makes a very unstable, even dangerous, tow. You MAY be able to get away with a waterbed frame, and air tube mattress, if you can find one in the proper size.
Your second question is easier to answer, you need tire size ST225/75R15, load range D. ST is a trailer tire, you need to use it instead of, say, an LT (light truck) tire, as it is constructed differently, with different rubber compounds for the unique conditions encountered for a towed trailer.
If you want a numerical tire, a 7.00x15 D tire will work, they are only available in an LT tire, though.
