RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-30-2015, 10:12 AM   #1
1971 31' Sovereign
1973 29' Ambassador
Palm Desert , California
I need to add a gray water tank
Has anyone done a tank that goes on either side of the frame like the fresh tank? Is there space to do that? I haven't removed the belly pan behind the axles to see.
That seems to be the best place to put it and would require the least amount of re-plumbing the shower and sinks.
Having a custom tank made is not a problem. I think I would rather have it go inside the frame rails rather than hanging below. Something similar to the way the fresh tank is held in shouldn't be difficult.
It seems like having the gray tank empty to the black tank and then out would be best for cleaning out the system.
I've seen some complicated gray water additions. I'm looking for the best solution that will work without complications. Thanks.
CaCraig is offline   Reply With Quote
Old 09-30-2015, 11:50 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
In your sovereign, you could probably use an exact duplicate of the freshwater tank (if yours is the same as what they put in '73), and support it the same way; you'd have to cut out one x-member, and replace it with a single piece of angle-iron...the tank is notched to fit that arrangement. The tanks are available from Inca plastics.
If not that, you can certainly use the tanks from VTS...I squeezed 2 into my 23-footer. You've got way more space to work with...no "squeezing" required.
check my thread...post 49 shows the tanks sitting in place.
http://www.airforums.com/forums/f36/...oor-79524.html
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-30-2015, 03:15 PM   #3
1971 31' Sovereign
1973 29' Ambassador
Thanks Chuck. Are those gray tanks about 25 gallons each? I guess I could get away with just one. I think my black tank is 21 gallons so that puts me close to my 50ish fresh water tank.
I was hoping someone here would know if those back bays are clear or if there's something running through them.
Old 09-30-2015, 04:19 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We installed two gray tanks in our '72 Sovereign. One is directly above the rear axle, and the second one is in the space behind the rear axle. I would hesitate going further back as that puts a lot more weight behind the axles, and those early 70 frames are just not all that strong to support 3 full tanks totally behind the axels. A concern if you ever have to travel with both gray and the black tank pretty full.
I ganged the two gray tanks together below the belly pan with the drain to the dump valve. I built my own tanks, but the VTS 21 gallon (55" x 21" x 5") match the size of my smaller gray tank, and it fits inside the belly pan completely. VTS didn't have them when I was in need of them.
If you look at our Little Girl Refurb Thread starting at post 168, and then again at 183, you can see how I built them. Starting at post 250 is where I install them.
Link: http://www.airforums.com/forums/f185...urb-50967.html
Hope that helps.
Chris
Old 09-30-2015, 04:24 PM   #5
ericpeltier's Avatar
Superior , Colorado
Consider what I'm thinking about for my Streamline: Make the black tank into a grey tank and get a cassette toilet for the black.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-30-2015, 07:06 PM   #6
1971 31' Sovereign
1973 29' Ambassador
Eric- I don't think the cassette toilet will work for me. I need a tank that'll hold about 14 days boondocking.
There are a couple of guys near me that will make a custom size tank for about ⅔ the price of the VTS tank and no extra charge for fittings. They are probably the same people that make the tanks for VTS.
So I'll probably mount it similarly to the fresh tank, closest to the back axle. Now I just need to figure out how I want it plumbed. I'd prefer to tie it into the black tank so it will help flush that out but I don't think that is possible because I need a valve below the floor. I'd also like to use the same vent as the black tank and that probably won't be difficult.
Old 10-01-2015, 07:50 AM   #7
Minno's Avatar
1972 31' Sovereign
We tied the gray and black tank vents together, and it works fine. My recommendation is to tie them together at a level that's above the toilet. That way you're insured to never have black tank stuff spilling into the gray tank via the vent.
Old 10-01-2015, 12:54 PM   #8
Tom T
Tom_T's Avatar
Orange , California
Vintage Trailer Supply sells them (repro of OE) & they're an advertiser on here. IIRC they're 16 gals each for the 60s-70s under floor-between 4" frame rails flavor.
Vintage Trailer Tanks: Fresh, Gray and Black
There are links to installation of them at their website, on here & if you google for it.
http://www.airforums.com/forums/f162...ly-130883.html
... & others ....
They are polypropylene so you'll need to get stainless steel straps or stirrups to hold 1-2 in between the AS floor frames.
I'll be doing one in our `60 Avion T20 - assuming they fit between its frame rails - whenever I remove the belly pan for re-riveting.
Good Luck!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 10-02-2015, 01:44 PM   #9
Superior , Colorado
Whoooeee. That's long. Maybe if you peed outside and cut back on the fiber?
2012 Nissan Armada
Most of China
Add Gray Water Tank to '60s Airstream Grand Master Waste Systems, Tanks & Totes 37 10-02-2014 11:26 AM
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 07:31 PM
Add Gray Tank to 70's Rear Bath dcheshire Waste Systems, Tanks & Totes 14 08-23-2013 09:37 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 10:19 PM
Rear Floor Renewal - Add Gray Tank? Paul Mayeux Waste Systems, Tanks & Totes 3 03-05-2003 11:29 AM
