Can I replace my exterior door on my 71 31 ft sovereign with a door from a 71 overland? if so how do you remove door? Do I simply drive out the long pin or is there some kind of holder or keeper I have to remove first.
All of the 71 doors are the same with a single hinge and cast frame. I had to rebuild the door on my 71 GT. Drive out the roll pin (this will not be easy) and then drive out the 1/4" hinge pin (this will also be difficult). You can also remove the nuts that hold the door to the hinge half and just leave the whole hinge assembly attached to the trailer.
