RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-18-2014, 09:51 AM   #1
1972 31' Sovereign
Orangeville , Ontario
Copper pipe and pex aren't the same size
Hello all;
So my husband found two holes in the copper pipe right at the back on the trailer, under the sink. Since we leave on a road trip to Nova Scotia on Tuesday, he decided to cut out the affected pipe and replace with pex. Problem is the pex won't fit onto the remaining copper pipe. Didn't want to get too involved after hearing his exasperated WTF's but does anyone know how this could be repaired....quickly.
Lori
Loripep is offline   Reply With Quote
Old 07-18-2014, 10:19 AM   #2
1972 31' Sovereign
Sorry, should add that the shark-bite adapter does not fit around the copper tubing enough though it should be the correct size.
Lori
Old 07-18-2014, 10:39 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Lori
There is a good possibility that the copper has been frozen and has swollen, if that is the case you may need to cut back until you find piping the right size for the fitting to "bite" on. Or you may need to pull out an entire section. One quick and dirty fix is to use a bit of rubber heater hose (like you would use on a car) and a couple of hose clamps. It can be stretched to fit over a swollen pipe and bridge the bad section. I have done this as a temporary repair until I could get to a place and time to do a proper repair.
Aaron
WBCCI #XXXX AIR #2495
Old 07-18-2014, 11:28 AM   #4
dznf0g's Avatar
Oswego , Illinois
Can you not sweat in a copper line repair...or is it too tight space wise?
-Rich-
Old 07-18-2014, 11:32 AM   #5
1974 Argosy 20
Kooskia , Idaho
The copper pipe has been frozen at some point and stretched, but not failed. Very very common problem you have run into. You will need to get to some part which has not been frozen and stretched, which may or may not be difficult. I have had to go to a copper fitting on the original piping, like a T or union, un solder it, and replace a short piece of copper with new in order to use fittings like shark bite.
Old 07-18-2014, 12:00 PM   #6
Zil
Curtis Wright
Eyren Haven , South Jersey
Also possible you have pex/pex fitting and not pex/copper. A quick fix temporary is as above, vinal tube to fit over the copper with clamps. Only for cold water.
Zil is offline   Reply With Quote
Old 07-18-2014, 12:03 PM   #7
Colorado Springs , Colorado
Consider a silicone tape such as Rescue Tapeģ Self-Fusing Silicone Tape . Since it is in a drain it needn't be food grade.
My son has used it for a radiator hose leak successfully.
minke is offline   Reply With Quote
Old 07-18-2014, 12:10 PM   #8
1974 Argosy 20
Kooskia , Idaho
The outside diameter of all nominal pipe size (say 1/2 inch) is the same. Sharkbite fittings in 1/2 inch will fit copper, pex, gray polly, and cpvc. Some other fittings are pipe specific, but not the Sharkbite the OP mentioned.
Copper Pipe Size? jr3149 LP Gas, Piping, Tanks & Regulators 16 01-27-2016 11:32 AM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 02:04 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 08:23 PM
Copper pipe size CBWELL Fresh Water Systems 10 09-07-2009 09:46 PM
Copper Pipe Size Larry71 Fresh Water Systems 5 05-20-2009 10:36 PM
