Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 - 1973 Sovereign
Old 05-12-2015, 04:08 PM   #1
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
Cooktop vent fan removal
Anyone know how this is done? I drilled out the rivets holding it in on the bottom and the side, but it won't move. There must be something I'm missing.
I can't find it mentioned in the service manual.
CaCraig is offline   Reply With Quote
Old 05-12-2015, 05:04 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Don't know about the older trailers, but my 2001 had four screws run through from the inside of the fan cavity into the bottom of the cabinet.
Al
Al and Missy is online now   Reply With Quote
Old 05-13-2015, 09:22 AM   #3
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
The 1971 has about 15 rivets all around the bottom and another 4 or 5 on the side of the cabinet. I have them all drilled out but it won't move.
Old 05-13-2015, 10:17 AM   #4
1955 22' Safari
Laredo , Texas
Pics might be helpful.
I just replaced mine but imagine things were different in 1955...
55AS is offline   Reply With Quote
Old 05-13-2015, 01:22 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
If yours is like mine, it has to come out from the outside. (Its on my list) Raise the exhaust cover door and take a look.
NavyCorpsman is offline   Reply With Quote
Old 05-13-2015, 01:56 PM   #6
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
On our Argosy, the round pipe goes through the roof under the vent and the entire vent structure appeared to have been assembled prior to installation (no easy way to dismantle in place). There was a copious amount of sealant around the vent pipe holding it in. I removed the vent cover, cut away all of the sealant and the whole thing came to the inside.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 05-13-2015, 04:06 PM   #7
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
I have a 69 and it does come out from the outside.
Must remove the roof vent covering the opening.
hugheym is offline   Reply With Quote
Old 05-14-2015, 12:34 AM   #8
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
I got it out. The upper cabinet must come out and then the rivets are drilled out to remove from the cabinet. I was hoping it would drop down after I removed the rivets.
Once I loosened all the screws holding the cabinet, the exhaust came out of the interior skin and i was able to put it on the floor. Here's a picture of the fan exhaust with the screen to keep critters out. My fan was hardly able to turn.
Old 05-15-2015, 08:56 AM   #9
Regular Guy
1978 31' Sovereign
It's a Boy!
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? pejokerst Airstream Classifieds 0 02-19-2014 08:45 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Where to get a Metal Cooktop Exhaust Vent Cover AudioMike Exterior Restoration Forum 8 07-24-2010 09:13 PM
Cooktop exhaust vent cover... crazylev LP Gas, Piping, Tanks & Regulators 3 05-07-2004 10:43 AM
Magic Chef Oven - Cooktop Cover 05ModPod Stoves, Ovens & Microwaves 14 03-03-2004 12:35 PM
