Old 06-09-2018, 01:33 AM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Axle Lift photo bomb
Old 06-09-2018, 01:35 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Old 06-09-2018, 01:50 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Ok, we took two 6’ sections of 3” x 3” x 3/8” angle and we welded one piece to each side of the frame after we removed the stock axles.
Next we marked the square notches that the old axles sat in onto the new sections of metal using a square making sure they were marked at EXACTLY the same fore and aft position as before.
Then we put the axles into the new notches and drilled out the new mounting holes in the new sections.
This gave us a three inch axle lift, and it allowed me to strengthen a weak spot in the frame at the same time. The fix has worked perfect for me for some time now, I got a much needed lift and by jacking hard on the rear of the trailer before welding the new sections in place I was able to fix the rear sag in my trailer. Win/win.
Old 06-09-2018, 02:05 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
This is the best picture I have that shows the slot in the frame that we transferred down to the new piece. The shock mounts nearly exactly in front of the old slot. It’s kind of hard to see in the other pictures.
Old 06-09-2018, 02:13 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
We cut the slots using an angle grinder with a cut off wheel. These slots will locate the axles, so try to be as precise as you can. Note that we made the slots the same depth as the stock slots, so therefore the 3” x 3” angle gave us a true 3” lift. Of course the height of the lift can be altered by the size of the angle.
Good Luck!!!
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 10:13 AM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Bomb an Airstream!! imeynstein General Interior Topics 49 04-26-2004 11:27 AM
