Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 - 1973 Sovereign
Old 03-05-2010, 11:36 AM   #1
kikileg's Avatar
1973 31' Sovereign
N/A moving , Colorado
1973 31' Sovereign Remodel
I will be posting photos beginning my first journey in to remodelling my 1973 31' Sovereign I just purchased. I will be doing a full remodel including moving the rear bath, new plumbing, new electrical....maybe even solar. I am going to start with removal of all interior items I will post shortly some photos of its current state, and ask some questions of the experts out there. I will post the current state of items that are of concern and look forward to the input and feedback...and since this is a great community, the HELP!!
Away we go!!!
kikileg is offline   Reply With Quote
Old 03-05-2010, 12:58 PM   #2
Away we go!!!
Unless the trailer is inside, the first thing you want to do is "weatherproof" it.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-05-2010, 01:24 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Andy is right, all of the caulking and window/door seals need replacing unless the PO was on top of all of this. Usually they aren't.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 03-06-2010, 12:31 AM   #4
Ottawa , ON
kikileg,
Good luck with your project. I'm always impressed when a new owner starts right off by gutting his (or her) trailer and taking it down to the bones right off the bat.
Is your new one that bad that you can't live with it for a while to see how it feels once you're used to it?
Or is it just that you couldn't find the layout you wanted in the trailers available in your area, and so you are determined to make it yourself?
Either way, if it's convenient for you, it would be nice to see pictures now before you do anything, just so we have a benchmark to go by.
Old 03-06-2010, 05:26 AM   #5
kikileg's Avatar
1973 31' Sovereign
Thanks Mike and Andy
Can you recommend the caulking to use and where to buy the window supplies?
You are right a couple of window show signs of water penetration..so I will do that first...
Old 03-06-2010, 05:28 AM   #6
kikileg's Avatar
1973 31' Sovereign
I will be putting up pictures
And I am changing all of it because I intend to take a year to simplify my life and live in it...
Originally Posted by Aage View Post
kikileg,
Old 03-06-2010, 12:30 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Kikileg,
Don't use silicone for caulking on an Airstream. Vulkem (its gray in color) is what you should use and you can order that from Inland RV, Vintage Trailer Supply, or Out of Doors Mart. The rubber window seals can also be ordered from these three places. Just tell them what kind of trailer you have and how much (in feet) you'll need.
Mike
1958 Overlander
4CU 1st VP
Old 03-06-2010, 03:28 PM   #8
The original window and door gaskets have been changed to a superior type, that offers a much better seal.
Also, check out the sewer vent pipe cover gaskets. They only last 2 to 3 years.
The access compartment gaskets should also be checked.
The 2 sealers to use is Vulkem for larger seams, and Par Bond for small seams. Vulkem can be used to seal the glass to metal area of the windows, as that gray gasket may also be leaking, especially around the wing windows, the stack windows and the vista view windows.
You should also check out the suspension system, to assure that the rubber rods are still serviceable. There is an article on how to do that in the Airstream Central section of this Forums.
You should also check the rear end for separation, which is somewhat common to the older trailers.
Once the trailer is waterproofed, then your attention can be on the work you wish to do on it, without fear of water damage.
Welcome to Airstreaming, and it's world of questions and answers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-06-2010, 05:00 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I am in the process of upgrading my '74 Argosy 26. If you are going to redo all of the plumbing, I would recommend PEX tubing for the fresh water lines. I used "FLAIR IT" fittings. No special tools required. Bought the fittings at, www.iPlumb.TV.com and the PEX tubing, Blue and Red at a place called Menards. I started a blog a while back and have posted a few pics.
GOOD LUCK ON YOUR PROJECT1
Old 03-06-2010, 05:06 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The web site address in the previous post is not correct. It is www.iplumb.tv . No ."com"
Old 03-07-2010, 12:50 PM   #11
kikileg's Avatar
1973 31' Sovereign
Windows and Exterior
Ok so I have photos of the windows ....
Anything come to mind....what should I look for...
Also, what about vent covers etc....
ID:	97608   Click image for larger version
ID:	97610   Click image for larger version
Old 03-07-2010, 12:56 PM   #12
kikileg's Avatar
1973 31' Sovereign
Exterior shots, What to do about the dent??
Here are some exterior shots...
How do I repair dents....especially the large one at the rear?
And what is the carbon steel bracket for on the underside near the front?
ID:	97612   Click image for larger version
ID:	97614   Click image for larger version
Old 03-07-2010, 01:01 PM   #13
The area on top and sides of each window need to possibly be cleaned up, and then resealed.
The area between the glass and sash (metal frame) on all the fixed windows, wing window, vista view and stacks, should all be cleaned and resealed with Vulkem sealer.
Cover the old gray gasket completely with the sealer.
That will eliminate all the leaks from the window framing.
Next, would be the gaskets on the back side of each opening window. Lastly, the access door, entrance door and sewer vent pipe cover gaskets, should be replaced, if not already done so.
Make sure you check the sewer vent pipe cover gaskets, as they only last 2 to 3 years. Removing one of the covers, will answer your questions.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-07-2010, 01:08 PM   #14
The front underside bracket, is a spare tire carrier.
The only real hope for that double dent, is replacement.
Otherwise, repair attempts will never make the stretched aluminum marks disappear.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-07-2010, 01:28 PM   #15
kikileg's Avatar
1973 31' Sovereign
Double Dent
Thanks Andy..is the replacement for that area a piece that can be purchased?
Or could you advise how to fix? Idea on approx cost?
Also would you provide your link for material for the windows...so I can order tomorrow..
Old 03-07-2010, 01:55 PM   #16
Segments cost several hundreds of dollars, each.
We, as a vendor, are not allowed to post prices on things we sell.
Click on the red part of our signature line. That gives you the information you asked for, on how to contact us.
Andy.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-07-2010, 02:05 PM   #17
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Question for Andy. The gasket between the glass and the metal frame, is that replaceable and where can I get it?
I have '85 Sovereign, the rear window has a small leak into the window well which does not have drain holes. Do you know why no drain holes?
Your comments may help several of us following the thread.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 03-07-2010, 02:32 PM   #18
Bill.
That between the window gasket is not available from Airstream, even though they make the windows.
Your Airstream is 25 years old. I would suppect that all the window gaskets have out lived their useful life and should be replaced.
Check the sewer vent pipe cover gaskets, as they only last 2 to 3 years.
Also check the access door and entrance door gaskets. They too, probably have seen their day.
Weep hole drains are not installed in the trailer windows, since they, by design, don't leak.
However, the gasket can age out, causing leaks.
Front and rear window leaks are more common to leaks in the clearance lights. They should be removed, cleaned up and resealed. Or, you can remove them and up grade to LED clearance lights which are far superior.
Adding drain holes in the bottom of the opening trailer window frames, is a bad idea.
It's far better to locate the reason for the collection of water, and correct it.
Anyd
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-10-2010, 01:02 PM   #19
kikileg's Avatar
1973 31' Sovereign
Interior Dimensions of the 31' Sovereign
Does anyone know where to find inside dimensions for the 31' Sovereign?
Thanks!
ID:	97855   Click image for larger version
Old 03-10-2010, 01:42 PM   #20
Thanks!
There are dozen of interior dimensions.
Which dimensions are you "exactly" looking for?
Andy Rogozinski
Inland RV Center
Corona, CA
Renovation to layout of 1973 31' Sovereign kikileg General Interior Topics 2 03-03-2010 06:47 AM
1973 31' Airstream Sovereign Land Yacht eBay Watch Airstreams on eBay 0 08-29-2009 10:00 AM
1973 Sovereign 31' Land yacht Joe1261 1970 - 1973 Sovereign 5 05-04-2009 05:03 PM
1973 Airstream 31' Sovereign Land Yacht eBay Watch Airstreams on eBay 0 04-06-2009 08:40 PM
