Old 03-20-2020, 12:40 AM   #1
Pastor Bruce's Avatar
1998 31' Excella 1000
Quartzsite , Arizona
Replacing front gaucho couch
Currently have "stock" convertible couch, with under couch drawer, in the front of my 31' 1998 Excella 1000, but would like to replace (uncomfortable seating). Problems are the two battery housings and a newly installed inverter/converter plus wire and cables that are in the area. Current frame of couch fits over components. Thought about having cabinet maker build a cabinet to fit under front windows to hide components underneath with cabinets for storage above, then using Euro-style chairs w/ottomans. But that potentially moves the chairs further into where the fold-down tables are located and be crowded. OR if someone has a replacement couch that will fit over the battery housings and inverter/converter, etc. I would consider that. Looking for what has worked for you. Thanks in advance for your ideas.
Pastor Bruce is offline   Reply With Quote
Old 04-14-2020, 05:23 PM   #2
Winston-Salem , North Carolina
Replacing with banquet
You bring up a great point with the less functional council in the front. One of the first things I did when I started renovated my 98 Excella 1000 was remove that couch and the tables. I worked with a local carpenter to build a u shaped banquet that curves around the back of the trailer. We created a stand off distance from the back to cover the battery box and relocated the battery shut off switch to the inside of a cabinet. I wanted this new area to function both as a work and dining area but also as a sleeping area. The center table (not in picture) comes down on a pedestal to create a bed. This system is not all too unique. One thing we did that’s different is build a TV into the backrest of one of the benches on an electric lift. See attached photos:
joelschneide is offline   Reply With Quote
Old 04-15-2020, 01:32 AM   #3
Thanks for sharing. Gives me something to think about that I had not considered. Presume there are cushions that fit on the benches/table and are used for the bed. I have seen similar designs. Looks great.
Old 04-15-2020, 04:24 AM   #4
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
joelschneide Now this is a great idea!
Can you show more pictures of your Televator and rebuild
Cheers Ultra
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
Ultraclassic is offline   Reply With Quote
Old 04-15-2020, 07:24 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Here is what I did. My trailer only had the one flip up table at the door and it is blocked about an inch or two by the loveseat. I plan to put the table on a drawer slide so it can slide forward about 2 inches to lift up but haven’t worked out the details yet.
The roadside recliner will only open to the first position with the footrest slanted unless the slide is out. It took some careful measuring to be sure it would open fully with the slide out
https://www.airforums.com/forums/f38...-a-195228.html
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Replacing Front Gaucho w/Dinette- flexible foldout beds my3sonsdad All Argosy Trailers 8 12-22-2011 06:07 PM
Classic FB Limited (Front Bed vs Front Couch) Sky 2006 - 2010 Classic (all lengths) 38 08-07-2011 07:42 PM
Replacing front couch in Tradewind Paul and Sue Cabinets, Counter Tops & Furnishings 8 04-25-2008 10:44 PM
Gaucho or couch bed John Greenlee Cabinets, Counter Tops & Furnishings 15 09-16-2004 07:10 PM
replacing front couch with futon gatorsharon General Interior Topics 15 08-02-2003 12:02 PM
