We would like to share with you our project Airstream,
My Wife and I were lucky enough to purchase a 1985 Excella 32'. Nothing unusual there you may think, But that is where the "normal" stops.
We had it shipped from Illinois to Queensland Australia where we live.
We had spent some time looking at all the caravan models available in Australia and came to the conclusion that they were all the same with some pretty garish interiors, and all rather Macho exteriors. Saying that they are all very capable vans off-road.
So after some searching we found our van and had it shipped.
When the Excell arrived it was clear that it needed to be lifted , there was no way it was going to see any form of track/offroad/river crossings or in some case never make it into a gas station.
So a plan was hatched to replace the suspension, increase the interior height ( Im a tad over 6ft 2") and make it in to a fully off-road off grid ( Boondocking) long term living van.
The initial plans for the suspension upgrade called for the floors to be lifted and have a good look at the chassis/ suspension. It then became apparent that we would need to scrap the original and build one designed for somewhat tougher conditions.
We approached several companies who built chassis and found a company -
www.limitlesschassis.com.au who were willing to undertake the challenge.
Now, as the Excella came from the USA , the electrical system had to be ripped out and we have to move the entrance door from the kerbside in the USA to the other side so it is on the kerb side in Oz.
During this discussion we decided that we did not want to lose the lounge room windows by putting the door there so we decided to extend the van by another 900mm.
New Chassis
The new chassis was designed and a load /stress analysis was done, with a maximum deflection of 8mm whilst hitting a substantial pot hole.The van will be rated to 4500kgs (9900lbs)manufacturing has now started and should be ready sometime next week. The Chassis is constructed with 150mm x 50mm x 3mm box section galvanised steel, with a separate 150mm x50 x 3mm "suspension dolly" mounted underneath the main chassis rails .
We also decided to add an extra axel making it a triple axel trailer. The suspension we chose is manufactured by Tuffride , its full airbag suspension with self levelling , and electric over hydraulic disk brakes
Wheels will be 17" running 275 75 R17 All terrain tyres.
Electrical system
We have spent some considerable time looking at what power system we would like , a load list was drawn up and then an evaluation was made on our typical consumption , As we plan to live full-time on the road in OZ , we want all the usual home comforts - Dish washer , washing machine/ fridge /freezer air-conditioning power for lighting , tv and charging . Our toilet is an electrical incinerator (cinderella _ made in Norway). Battery storage will be a system made by OZxCORP 51v 14.3kw with a 5kw inverter (
www.ozxcorp.com.au) the system will be replenished by a 5kw rooftop extendable solar array., with options to charge from our truck whilst driving and 240v if we are plugged in The battery is designed to sit beneath the chassis between the chassis rails and is completely maintenance free,It has its own fire suppression system and is plug and play , weighing about 133 kgs all up .
Water capacity
At the moment we have not decided on the amount of water capacity to install. We are thinking in the region of 5-600ltrs , with just a grey tank, no black tank is needed as the toilet is an incinerator (Grey tanks are required if we want to camp in national parks), We are fortunate enough to have a large tow car that has ample capacity to carry another 1000ltrs if we decide. We have looked at air to water generators , and have found a company that manufactures air to water generators for off grid living - we may incorporate that on our tow car. to extend our time off grid.
Interior
The interior will be split into 3 section kitchen /living area , bathroom , and bedroom It will be a centre bathroom with a full size walk in shower , toilet and decent sized wash basin ,
the bedroom will have a Kingsize bed ( 1.8m wide by 2.10 long )
Kitchen will be facing the front widows and come down the side where the door used to be .
Floor
The floor will be a single piece (almost 11m long) 40mm composite panel, 1/3 the weight of the usual plywood used. ( so no joins) this will be bonded to the chassis and the shell fixed onto this
The Whole interior will be modelled on the Orient Express, with Brass /leather and wood.
Outside
All service items like water heater (12kw diesel heater air compressor/ tank , water filtration system/ High pressure washer will be mounted between the chassis outriggers and the bottom of the van ( as we have extended the height of the chassis ,we hope to have about 450 mm depth below the floor)
One of our requests was to have a pull out deck built into the chassis , this is still in the design stage but will most likely extend from the kitchen to the bathroom .
Tow vehicle
Earlier this year we were fortunate enough to win at auction an ex ADF ( Australian Defence Force )Unimog U1700L
this is one of the most capable off-road trucks you can get , some small modifications have already taken place intercooler , turbo and exhaust upgrade,
taller wider wheels ( 395 85 R20)will be arriving soon.
You will see us coming
We have started a you tube channel and insta, so if you want to head over and have a look , please do, Like the Airstream this is a work in progress.We will show what we are upto with the van and unimog .
insta : post cards of a traveller .
youtube.com/@postcards_of_a_traveller
I work international and there goes a few months between work and project time so progress is somewhat slow. Ill post some pictures and hope you enjoy something a little different
Cheers
Louie
