I've been a little quiet in this thread, so I figured I would catch up with what I've been fixing in the last few months. I installed the replacement door latch, so now we can open the door from the inside. That's an important safety feature, clearly.
I also replaced the Everpure water filter housing, which required buying a lot of new adapters. The one that was leaking in the trailer had been put in by someone who preferred solid copper pipes instead of stainless steel water supply lines. The copper pipes were cracking here and there from vibration work hardening. Also, hard water deposits made getting the components apart very difficult, and there were lots of hard water deposits in the old filter housing itself. Well, with some help from the very helpful lady in the plumbing section of my local hardware store, I installed proper stainless steel hoses and the new filter housing is once again mounted to the wall under the sink.
The one drawback is that I had to disconnect the drains for the two kitchen sinks to get better access to do the work at the back of the under-sink cabinet, and I twisted one of the drains free from the sink, so I have to reseal that before I can fill the left basin with water to wash dishes. It's been a minor drip, soaked up with a towel under the sink, but I should really fix that soon.
I also still have to replace the break-away controller. I have no idea why I haven't replaced that yet, since I've towed the trailer several times without replacing that break-away gadget. Pure stupidity. I've got to do that tomorrow too, especially since it is only three wires and one screw.
Hmmm, what else did I do in four months since my last post? I bought new mattresses. I cleaned the thing from stem to stern inside, and it needs it all over again after a few trips. I also need to wash the outside again. I still haven't replaced the light bulbs in the control panel... I should do that too, once I figure out how to get those cardboard tubes off the bulbs out.
Scott
