Hi airstreamers we live on the North Island of New Zealand. With a total of 5 million people and 63 registered Airstream travel trailers!
After selling my 32’ fishing boat I started looking for something different and within 2 weeks of serious looking an Airstream came up for sale, needs some TLC the advertisement said.
I’m one for a project, so I went and had a look.
Next minute I’m driving home with a
1966 28’ Ambassador, Airstream travel trailer in tow.
Must add I’d never seen one in real life, only in books and magazines.
If you don’t count the coffee trailer in the Auckland airport.
Well the first thing I did once home was, of course.. dismantled the interior, removed the inner skin, I’ve never seen such a collection of fossilised squirrels and rodents in my life, removed all the rivets from around the floor area and lifted the shell off the chassis. Ripped up the rotten flooring.
Welded some more steel into the chassis, sandblasted and painted the chassis, and replaced the floor with marine plywood, ran new gas lines, (NZ requirements) rebuilt the axles, replaced the insulation under the floor and replaced the sub floor. Then it was time to replace the shell.
Riveted the body back onto the chassis, filled the walls with R3.2 insulation, ran 230 volt cables and new inverter (NZ requirements) ran all new
12 volt system, fibreglassed up all the holes in the original end caps and fitted them back into place and replaced the inner walls with full length aluminium sheets.
I have made a new bed (island walk around) in the front. It lifts up for storage and has the pot water tank under it.
Made a cabinet for the switch board, fridge/freezer (full size) and a pullout pantry, made a set of 6 draws for under the 8’ long kitchen bench, and a shower wall with a cavity sliding door. The shower is luxurious 3’ x 4’ base, with rain head and handheld wand.
Oh and I had to replace the water heater, 3 way fridge, and gas hob to meet NZ standard.
I forgot to mention the 250 plus hours of cutting and polishing that I did while recovering from shoulder surgery.
Got the floor covering down a few days ago, one sheet of linoleum that looks like polished concrete.
All the furniture is now going in for the final fit and finish. A huge sigh of relief because now I can see everything I’ve designed in my head and fabricated on the shed floor, coming together at long last.
In short I’m almost 2 years into the renovation and hopefully will be Airstreaming around New Zealand by August/September (this year)
