Old 06-14-2021, 11:25 AM   #1
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
Door handle
I have a Ď69 Ambassador. Has anyone changed the door handle to the modified trimark sold at inland rv? I have one, with no instructions. Inland canít answer phones due to COVID, I guess it spreads though phones? Anyway I have no directions. It doesnít look that hard but it would be great to see what others did, and maybe some directions. Thanks
lahrfarm is offline   Reply With Quote
Old 06-15-2021, 05:04 PM   #2
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
Inland rv
Is there any way to get ahold of them? They donít take phone calls, donít answer email, or messenger. If someone lives near the dealership, Iíd pay you to get the instructions and send them to me. Lol
Have a blessed day !
TAC OK-5
Old 06-15-2021, 05:59 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The instructions aren't that critical. You have the latch assembly in hand, and this will show you where the door latch should go, and where the new hole needs to be created for the deadbolt. There are plenty of folks who have retrofitted a more modern latch assembly to an old door without any kind of instruction, template, or kit. You really can eyeball your way through the process.
good luck!
Old 06-15-2021, 07:12 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Belegedhel is right. You just gotta dive in and do what it takes to make it work.
My son's 69 Globe Trotter likely had the same Bargman lock that your trailer likely had. The 69 model year has cast aluminum door frames (verify this on your trailer) which is quite thick requiring a rather long 3 1/2" set back, center of door knob to end of lockbolt.
Rebuilt Bargman locks are expensive. People buy them to keep the trailer original. I have a 75 Overlander 27'. It had a KT level style lock on it that Airstream used through the 70s. KT locks are problematic also.
So I removed the Bargman lock from the 69 and sold it for parts. Then I removed the KT lock from the 75 Overlander and installed it on the Globe Trotter. I'm hoping it will last a while, see photo.
Then I installed a new Korhee RV lever style lock ($50) on my Overlander. Changing locks is a job, but can be done by us armatures. It requires making a patch on the door skins, inside and out. It requires positioning and cutting a lockbolt hole in the door frame. And sometimes it requires three hands.
See photo.
David
Name:	2011 Door Lock Installed-800x600.JPG
ID:	397537   Click image for larger version
Name:	2105 Korhee Lock Outside-800x600.JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-16-2021, 06:56 AM   #5
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
Iím sure I can do it without the introductions. I am actually just irritated that Inlands customer service is so horrible. LOL
TAC OK-5
Old 06-16-2021, 06:19 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Inland used to be an excellent vintage Airstream parts supplier. But they have gone downhill over the years. I too have had bad experiences from them. They will get what they deserve; less business.
David
new handle of door-preserve existing handle waninae39 Windows, Doors, Locks & Vents 0 05-11-2019 07:48 PM
2016 Classic: Refrigerator door dented by pantry door handle dmslawson General Repair Forum 21 09-03-2016 11:56 AM
Door handle for outside of screen door RTurnConn Exterior Storage Compartments & Access Doors 1 08-27-2011 09:16 PM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 08:37 PM
