Old 02-28-2021, 09:24 AM   #1
1977 31' Sovereign
Kelowna , British Columbia
Wing Window Tie Bar
I am redoing my Wing Window on my 1977 Soveriegn. There is a vertical tie bar that needs to be removed however removal requires the installation of a new tie bar. Does anyone know where you can get a replacement tie bar or are there some other ideas for reinstallation that anyone has used. Thanks
Murman117 is offline   Reply With Quote
Old 02-28-2021, 08:24 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I don't believe that I bought new tie bars when I rebuilt my wing windows. I soaked the tie bars with penetrating oil, then I put a wooden block at the bottom of the bar and hit the block with a pneumatic hammer. Drove it right up and off without any noticeable deformation. As far as places to look for replacements, I would try Outofdoorsmart.com and vintagetrailersupply.com.
good luck!
Old 02-28-2021, 09:38 PM   #3
Remember, Safety Third
Jim & Susan's Avatar
Possum Trot , Georgia
Times two. I did it pretty much the same way, but with a block of wood and a rubber mallet.
Agree on both of those Vendors, they are outstanding. I have purchased from them seversl times and have received superior service on every order.
www.nesa.org
Air No. 6427
wing window tie bar bimpy Windows & Screens 10 02-12-2013 01:03 PM
'76 Safari wing window 'splice bar' wanted nhdubfan Windows & Screens 15 08-10-2009 09:50 PM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
